CD player swap
Old Mar 31, 2005 | 02:18 AM
white80zred89rs's Avatar
Car: 89 camaro rs
Engine: 305 TBI
CD player swap
I have an '89 RS with the stock tape player. I want a CD player, but I'd like to keep a factory look. Would a CD player from a later 4th gen camaro, or a cavalier, blazer, etc. fit in my car? Is the plug in in the back similar or the same, and would my factory speakers be able to handle it?
thanx for the advise!
white80zred89rs
Old Mar 31, 2005 | 12:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Try doing a search. It's been discussed a bunch of times, and one member here sucessfully put a 4th gen cd player into his car. The wiring issue should be straight forward (if you're familiar with wiring at all). I do recall that he had to do a little work with mounting brackets, but I don't think it was anything complicated or overly difficult.
Your stock speakers will handle it just fine, although with the new radio (assuming you use a late-4th gen or late truck radio) is good enough that upgrading your speakers will provide quite noticable benefits.
Old Mar 31, 2005 | 04:37 PM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
I put a 4th gen monsoon cd player in my 87 and there way no major modifications to do. I did however have to swap my old harness for a new 21 pin harness but it wasn't bad.
Old Dec 4, 2005 | 01:03 PM
Red1992V6Rs's Avatar
Car: 1992 RS
Engine: 3.1
I was also thinking about doing a 4th gen cd player swap. Does the unit just slide right into where the stock one goes? Do they have the same dimensions? I have little to no knowledge about car audio so as much info i can get would be great.
kairles
Oct 26, 2015 09:13 PM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
Ducati900ss
Sep 2, 2015 09:05 AM
Zachattack0925
Aug 12, 2015 09:52 PM
