Dust cover on subs pushed in, how do I get it back out?
Old May 4, 2005 | 10:41 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My JL 10w3's center dust cover got pushed in and now I'm trying to find a way to get it back out? Any ideas?
Old May 5, 2005 | 08:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Some have had good luck using a shop back to suck it out. I've never found that to be particularly effective.
What typically works best for me is to stick a piece of tape to it, and press the tape so that it's stuck well. Tug on the tape to pull up the dust cap, then peel the tape off.
Others have made small pin holes, and put a hook type device through the pinhole to pull it up, but then you have a visible pinhole.
Another solution is to carefully cut the dustcap off of the cone with a razor, being very careful to only cut through the glue. Once it's off, straighten it out and reglue it.
Old May 5, 2005 | 08:20 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
while you're in there, check out the voicecoils...
how would the sub sound with the dustcap completely removed?
would the box then become unsealed?
Old May 6, 2005 | 12:39 PM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Does it have a vented pole piece (ie, a hole in the magnet that allows air to move up and cool the voice coil)? Most modern subs are. If so, removing the dust cap would be the same as having a big hole in the cone.
However, having a vented pole piece means that u can reach in thru the hole in the magnet. When this happened to my buddy's sub, we used about 125psi compressed air to blow the cap back out. Just hold onto the cone so that it can't reach full excursion and rip the suspension. Start w/ maybe 80psi and increase as necessary.
Old May 6, 2005 | 12:41 PM
ScrapMaker's Avatar
sounds like you're asking for a violent flying-projectile!
Old May 6, 2005 | 02:27 PM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Well u could rip the cone off if u'r not careful, but it worked perfectly for my buddy's sub... it didn't do any damage to the sub and u couldn't even tell the dustcap had been dented.
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
