760w amp with these subs...?
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
How would the Pioneer GM-5100T amp work with 2 12" audiobahn AW1251SE subs?
pioneer amp info:
Peak Music Power 760 Watts
Number of Channels 2
Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
Continuous Power (4 ohm) 125W x 2
Continuous Power (2 ohm) 190W x 2
Continuous Power Bridged (4 ohm) 380W x 1
Frequency Response 10Hz ~ 50kHz
sub info:
Frequency Response: 24Hz-1kHz
Magnet Weight: 45 Oz
Efficiency: 92.1dB
Impedance: Dual 4 - 2 - 8 Ohm
RMS Power Handling: 400 Watts
Peak Power Handling: 800 Watts
pioneer amp info:
sub info:
Efficiency: 92.1dB
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Although you could certainly get a lot more out of a bigger amp, those subs should still do pretty well with that amp as long as you don't try to overdrive it.
raymondandretti
Sep 27, 2015 06:43 PM
