How to remove a power antenna?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Mine works and I'm shaving my antenna so I'm curious how hard it is to remove it without damaging it.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You have to remove the right front wheel well liner, and then you can access the bolt that hold it on by reaching in thru there, Much easier than pulling the fender to do it. Will probably have to remove the passenger's kick panel inside the car to thread out the wiring harness.
If it still works, ya wanna send it to me?
