weird speakers in the back
Old Jul 16, 2005 | 01:29 AM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
Transmission: 700R4, T56
wellllll i took off my sail panels expecting to find some 6x9's, but instead i've got this plastic housing holding a 4x6 and a 5.25...i ditched the 6x9's i was going to install and got pioneer 3 way 4x6's..4 of them total (2 for the front) and 2 rockford 5.25's..i hope it sounds good but do you think i'll need to amp the speakers? i'm running a pioneer premier 750 and i have 2 12" subs going in too.
whats up with the speakers int he back though..was that something included with the performance sound? anyone else have this?
Old Jul 16, 2005 | 02:33 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
i have heard that it was in cars that had a special option for an upgraded stereo system in the cars.. There have bee a few other people who have had the same speakers and have wondered.. I think that there might have been built in amps on the back of some of the speakers though.. not sure as I did not have that ( made it nicer when i upgraded all my speakers and put subs in to run the 2 amps (one for the 4 regular speakers and one for the subs)
Old Jul 16, 2005 | 12:14 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
You should defantly run an amp for your subs if for no other reason than your head is ONLY suposed to have 4 ohm loads put on it. Others have wired their subs to their rear speakers, but I don't approve. This also brings up an interesting point of trying to run a 4x6 and a 5.25 off the same channel...
More info on the performance sound package (that's what your rear setup is called) can be found in this thread: https://www.thirdgen.org/techbb2/sho...hreadid=306037
Old Jul 16, 2005 | 05:17 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
yea i'm running a seperate 2 channel amp to the subs and i have the rear 4x6's and 5.25's on the same channel because apparently the original head unit was 6 channel and my premier is 4..there was no power going to either 5.25's, so i put them on the same channel as the 4x6..think that will be a problem? where i thought there wouldnt be enough sound, it actually sounds pretty good..there isnt much bass but the highs and mids are there so when the subs go in i think i'll be pleased with it.
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
89lsc
Aug 14, 2015 04:58 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
