amp problem.
Old Jul 19, 2005 | 02:34 PM
i_luv_honda!'s Avatar
Car: 1983 camaro z28
Transmission: just got fixed~
amp problem.
its pretty lame but i need to know how to run 2 amps because i have a small 300 watt amp runnin to the 6x9's and i need to run a bigger amp to go to the kicker comp in the back and i dont know to do so.
Old Jul 19, 2005 | 05:01 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
how many rca cables do u have out of ur cd player?
Old Jul 19, 2005 | 05:02 PM
i only have 2 which run to the smaller amp
Old Jul 19, 2005 | 05:37 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Go out and pick up a distributer block. You can get whole kits if you want. You might want to check out other vendors for more options (ex: cardomain fused blocks and unfused blocks. there are others too)
You will need to run another set of rca's for the sub amp.
Old Jul 20, 2005 | 09:06 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
If you are just using 2 amps then get a short jumper wire to go between the remote, power, and ground. Some amps have RCA ins and outs, if not, then get a simple Y splitter.
Old Jul 21, 2005 | 01:45 PM
thanks for all the help i'm goign to pick up my second amp in a few days and ill let ya know how it works out thanks again.
Old Jul 21, 2005 | 08:08 PM
Gummie's Avatar
Car: 88 GTA
I would generally discourage this, especially if you're going to be using higher power amps. Replace the wire that's running to your battery with something thicker (4/2/0) at the very least. Blocks are not that expensive at all...
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
