what to clean sub with?
Old Aug 21, 2005 | 04:47 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
a guy told me the other day that i could use WD40 to clean the cone of my sub, he also said it would help my "foam surround" from dry-rotting. anyone heeard of this???
that got me thinking... what about armor-all? thanks guys.
Old Aug 21, 2005 | 06:41 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
never heard of it. i imagine it would make your sub shiny until it dried up, and probably not be very good for it.
armorall however is fine to use on your speakers.
Old Aug 21, 2005 | 08:13 PM
1meanGTA's Avatar
actually though, that was mike, the maker of soundsplinter speakers that told me that. my rl-p has a rubber surround. so im not positive armorall will be good for a foam surround but it shouldnt hurt. try it on a small portion first.
Old Aug 22, 2005 | 07:53 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Don't think you should use WD-40 on rubber...
Old Aug 22, 2005 | 08:38 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I've heard armorall cracking dashes and drying them out so I definitely wouldn't use it. How about a damp cloth?
Old Aug 22, 2005 | 03:57 PM
Car: 89 camaro rs
Engine: 305 tbi
ill just test a spot. first ill read what the armor-all says about foam. i think ill stay away from wd40.
Old Aug 22, 2005 | 05:27 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
All of the subs that I have had I have cleaned with Black Magic. It comes as a tire cleaner and there is an interior cleaner as well. I have always used the interior cleaner on my subs and on my interior and I love it. Might give it a try.
Old Aug 22, 2005 | 06:35 PM
Car: 89 camaro rs
Engine: 305 tbi
did u ever see its effects on foam surrounds? thanks.
Old Aug 23, 2005 | 07:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Most interior protectants use silicone, which is something I absolutely WOULD NOT put near foam surrounds.
Use a damp cloth to clean your subs. Once you get them clean, keep the slurpees away from them and dust them off once a week with a california car duster. That will prevent you from needing to ever clean them again.
Old Aug 24, 2005 | 12:09 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I second that. Damp cloth, nothing more. My subs are 3 years old, in the sun (hatch) and never cracked.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
