Which terminal is which?
Old Oct 3, 2005 | 07:10 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Figures, I threw out my instructions. Does anyone know which tab on my kenwood 6x9s is which? + or -. There is a narrow one and a wider one. I think I have them wired 180 deg off. I have the - on the wide one and then + on the narrow one.
Old Oct 3, 2005 | 09:17 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
mine came w/ wires and the ends on them already so that should tell u the wire w/ the line or dash or black or stripe is neg. the solid is positive.
Old Oct 3, 2005 | 09:31 PM
MattODoom's Avatar
Car: '88 G T/A
I got these speakers from a friend, no wires on them
Are the speakers supposed to make a big pop and do their max excursion when the amp kicks on? That is what made me think they are wired wrong.
Old Oct 3, 2005 | 11:02 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Typically if the speaker has a wide and narrow terminal, then the wide one is positive.
Old Oct 4, 2005 | 05:33 AM
MattODoom's Avatar
Car: '88 G T/A
Thank you!
Old Oct 4, 2005 | 06:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I agree with Rez, but when in doubt, find a 9 volt battery and touch it to the terminals. If the cone jumps up, you've got the + side of the battery on the + terminal. If the cone jumps in, then you've got the + of the battery on the - terminal.
Old Oct 4, 2005 | 09:32 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Any non-powered speaker you catch doing that has in all probability nothing to do with the speaker. The electronics do not exist in a non-powered speaker to do this on its own. My guess is your amp is sending this signal down the line -- probably always has, but you just now noticed it. How often in the past did you actually watch your speakers when the amp turned on?
Old Oct 4, 2005 | 09:58 AM
MattODoom's Avatar
Car: '88 G T/A
This is the first time ive run these speakers on the amp. The amp is brand new. Going to switch around the polarity when I get home from school, work and college.
Thanks for the help, ill let you know how it goes!
Hotrodboba400
Dec 10, 2019 07:07 PM
J.C. Denton
Sep 21, 2015 04:23 PM
eustodp
Sep 20, 2015 05:09 PM
Denricci22
Sep 18, 2015 09:02 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
