grounding multiple amps
Old Feb 1, 2006 | 11:17 AM
Dracul's Avatar
Car: 1983 Camaro z28
Engine: 5.7
Transmission: 5spd
when running multiple amps, do i have to ground them at the same spot? or can i just ground them individually?
Old Feb 1, 2006 | 12:51 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you can ground them all at multiple places. the only possible issue might be minor issues with ground loops. and that should really only be of any concern if the voltage isn't very well regulated. but I don't think that would be much of a problem.
Old Feb 1, 2006 | 12:58 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
You can get a distribution block and ground them through that.
Old Feb 1, 2006 | 02:20 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
I bought a stinger power & ground distirbution block, its pretty cool because it has the power & ground on the same block. It came w/ 2 4 ga inputs (1 for power & the other for the ground) & 4 4 or 8 ga outputs (2 for power & 2 for ground), perfect for a 2 amp set-up.
Old Feb 1, 2006 | 03:09 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
To avoid the potential for ground loops, the best practice is to ground the amps in the same spot, or use a distribution block for your grounding.
That's not to say that it won't work properly if you use separate grounds, but you do allow for the potential for a ground loop to occur, especially over time as one or both of the ground points begins to oxidize and lower conductivity.
Old Feb 1, 2006 | 03:12 PM
Dracul's Avatar
Engine: 5.7
Transmission: 5spd
ok thanks for the answers.. i don't feel like buying another distro block so i'll just ground them at the same spot..
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
gta892000
Sep 16, 2015 12:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
