Fuses keep blowing on amp
Old Feb 9, 2006 | 05:12 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
The system has run for 2 years w/o any problems. Then all the sudden it quite working. First I checked the main fuse on the Positive cable from battery. It was bad so i replaced it. Still the amp won't turn on so i checked the fuses on the amp and they are both blown so i replaced them and they blow out right away. What could cause this?
Old Feb 9, 2006 | 05:18 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Blown speaker(s) or a pinched speaker wire that's grounding out to the chassis.
Old Feb 9, 2006 | 05:34 PM
trueburton's Avatar
I kinda thought it might be a wire grounded to chassis cause I had that happen in my old car except it wasn't fused and started fire.
Old Feb 9, 2006 | 09:03 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
A little more info would be helpful. I don't that anything is grounding out unless it's one of the speaker wires which isn't all that likely. Even if one is grounded out I'm not sure that would be enough to pop fuses.
When does the amp pop its fuse? When you turn it on, when you're playing music, etc?
Also, under what circumstances were the fuses initally blown?
Old Feb 11, 2006 | 10:04 AM
trueburton's Avatar
Not sure I just noticed the subs weren't working one day. I don't crank them way up and be obnocious. I just like a little bass to my music so i'm sure it's not that i had it cranked too high or anything. The fuses blow as soon as you turn the amp on.
Old Feb 12, 2006 | 10:23 PM
Gummie's Avatar
Car: 88 GTA
If the fuses blow the instant you turn on the amp odds are the power supply is shot. Get in contact with the amp maker to see what they can suggest.
Old Feb 13, 2006 | 08:12 AM
violentgod1's Avatar
Car: 1989 RS
Engine: 305 ci v8 LO3
Transmission: WC T5
yeah its def got to be a short somewhere. Or if there is a spot you didnt check where maybe positive and negative are crossed that will cause your fuses to blow right away.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
Fanatic1074
Oct 2, 2015 03:47 PM
raymondandretti
Sep 27, 2015 06:43 PM
