amp problem
Old Feb 24, 2006 | 07:26 PM
xfactor200289's Avatar
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
amp problem
i have jensen amp when i turn on the stereo the sub pushs up for about 1-2 minuets and then starts working fine
Old Feb 24, 2006 | 11:30 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
The subs push up as in the amp pushes them up and then they stay raised for a minute or two? Depending on how much power your amp is putting out that might be extremely detrimental to your subs health. Try unplugging the RCAs from the amp to see if that makes any difference.
Old Feb 25, 2006 | 05:42 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
it is a jensen 200wbridgable amp. tried unplugging the rca jacks and sub still stays pushed up for 1-2 minuetes.
Old Feb 26, 2006 | 12:14 AM
Gummie's Avatar
Car: 88 GTA
I was just trying to figure out if it was the amp's fault or the head's fault. Your subs are staying up because the amp is sending them constant positive voltage. Your goal is to try to figure out why. I've honestly got no idea.
Old Feb 26, 2006 | 09:45 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
That amp is done. Get it off your subs before you kill them.
Old Feb 26, 2006 | 05:40 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
thanks for info
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
