why MDF?
Old Apr 3, 2006 | 11:43 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
why MDF?
Is there any reason why i can't use 3/4" plywood to build a sub box in the hatch well? I know youre supposed to use MDF or fiberglass, but whats the difference? I can seal plywood corners just the same, and its incredibly cheaper.
Old Apr 4, 2006 | 12:19 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
whats the big deal, a 4 foot by 8 foot sheet of mdf is under 20 bucks. i made a freakin huge box with 2 sheets.
hold a piece of plywood. break it over your knee. try that with mdf. now stick a 50 pound sub in a plywood box and give it a few thousand watts.
Old Apr 4, 2006 | 12:20 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
MDF isn't expensive. You can get a 4x8 sheet for around $20-25 at lowes/home depot. It's also uniformly dense, won't have any knots in it, etc; all together a much better material for building enclosures than plywood. Sure, there are alternatives but they all cost a good deal more (nice quality oak, birch, sonotube, etc).
In a nut shell MDF is cheap ($25 is dirt cheap in the world of audio - my fiberglass box is probably hovering just under $200 in supplies thus far). It also is extremely easy to work with and will never have any flaws, imperfections, etc.
Edit: mean brings up another good point, MDF doesn't flex much at all.
Old Apr 4, 2006 | 10:27 AM
Trans It's Avatar
MDF is preferred over wood in speaker cabinet building because it controls cabinet vibrations/resonances better than wood. A wood cabinet when hit on the side will have a 'ring' to it, while a MDF cab will have a dull 'thud'. It really depends on how the cab is made though. There's no law saying you can't use wood. Plywood is much better than solid wood, as the ply layers tame things down a bit like MDF. For a car I'd think a plywood cab would be fine (3/4"). Do the right internal bracing and line it with something to absorb the back wave etc.
DonCamaro
Car Audio
21
Apr 19, 2003 09:00 PM
BadBowTie
Car Audio
Nov 12, 2002 07:04 PM
89blackGTA
Car Audio
Sep 15, 2002 08:04 PM
Kingtal0n
Car Audio
Jul 2, 2002 05:00 AM
