Cd player fitment
Old Apr 8, 2006 | 08:58 PM
DrummerDad's Avatar
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
Cd player fitment
I tried to search but got nothing. I am sure this has been asked before, but Ill give it a go.
I need to know if a factory sunfire cd player will fit my 91 firebird. I have found a few on e-bay, and elsewhere, and need to know if it will work. Im not scared to do a little trimming, or wiring. I am sure someone here has swapped one in. Which ones do I need to get? Will one like this: eBay: Delco GM Pontiac OEM AM/FM CD player radio 94-01 (item 9708796993 end time Apr-12-06 18:01:55 PDT)
Work? I am only interested in a factory pontiac radio. I like the stock appearance.
Old Apr 8, 2006 | 09:46 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
... I have no idea. Sorry bro.
Old Apr 8, 2006 | 10:00 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
From looking at the picture I would say that it should fit without any problems although I have no direct experience. Should fit like any other double din unit.
Old Apr 8, 2006 | 10:58 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
my best guess is that if anything it will fit except the right side bracket and possibly left will have to be changed to go into the radio pod.
Old Apr 11, 2006 | 10:56 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Drops right in. Use the stock Camaro brackets and wire it up!
You may need an antenna adaptor (I know 92+ did, not sure of 91) as the GM antenna was smaller than the 80's ones.
Old Apr 24, 2006 | 04:36 PM
DrummerDad's Avatar
Transmission: auto
Well, Ill be buying a monsoon from a guy in our club. Its out of a '99. But how do I disarm the antitheft function? Im sure it has one, and dont know how it works. I had one in another car of mine, and it required a 4 digit code to be entered before it would work. Is that how these 4th gen radios work?
Old Apr 24, 2006 | 04:42 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
EDIT: I guess I was wrong. I thought the Monsoon had external amps:
https://www.thirdgen.org/forums/car-...hlight=monsoon
Old Apr 24, 2006 | 04:44 PM
DrummerDad's Avatar
Transmission: auto
Okay, I found this on another site:
7.Theftloc Bypass
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed 2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 202107, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Update…
Originally posted by I_EAT_Z28
Try this. I found it on another forum.
The dealer quote listed on the thread does not work, but i was able to find one on the internet. The 5-digit code which did it for me was 06010. Before this a 2 must be entered for Pontiac, and an asterisk after, so when prompted after calling 1-800-537-5140, pontiac guys enter: 206010. The website where i got the dealer code is here: Google cache.
But, will this work, if the radio is my car? And not in the original car?
And I did a search and found one or two who said they had used a monsoon. I guess Ill do a more thorough search.
jrdturbo
Mar 31, 2016 02:58 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Linson
Oct 1, 2015 09:50 PM
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
