big amp, where to mount?
Old Apr 13, 2006 | 04:15 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
This thing is not huge, but pretty big. Any ideas where I can mount it in a stealth location??
I don't want to mount it in the spare tire area because I'm trying to find someone to make me a stealth sub box for that area, and I use the glovebox in the trunk. It is too big to mount flush in one of the back bucket seats...
Any other ideas?
Attached Thumbnails big amp, where to mount?-dscn5253.jpg   big amp, where to mount?-dscn5252.jpg
Old Apr 13, 2006 | 04:22 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
The glove box isn't that big so you might be able to fit it underneath it. Other options include building it into your enclosure (generally not recommended) or just screwing it down to the carpet on the hump like the first picture. Just be careful not to use screws that are too long because the gas tank is right below the sheet metal.
Old Apr 13, 2006 | 04:42 PM
Brisk's Avatar
ya I tried to fit it in the glovebox side already.. it won't work unless I remove the box altogether.. which I wouldn't want to do. I was thinking of building a panel and mount it to the rear piece/side where the hatch motor sits.. and mount it there sort of like an amp rack.
anyone done something similar before?
Old Apr 13, 2006 | 06:34 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
im planning on making an amp rack to go where one of my back seats goes, with one of the amps on the angle and one flat where the bottom part of the seat was. my amps are 19 inches and 25 inches. thing is probably too big to mount in the seat if you have split seats.
is that the 2500?
Old Apr 15, 2006 | 01:36 AM
Brisk's Avatar
it is the 700.5
Old Apr 19, 2006 | 01:51 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
My KX800.4 plopped perfectly right at the bottom of the lowest rear trunk area. If you wanted to conceal it you could make a discreet carpeted panel that sits across the two lower humps just making the rear look shallower (don’t forget some kind of vent for Mr. Amp down there).
Old Apr 30, 2006 | 05:07 PM
shad0wsfall7's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
not to hijack but...
how short screws do you need to use in order to mount the amp above the gas tank without going into the gas tank?
Old Apr 30, 2006 | 09:47 PM
Gummie's Avatar
Car: 88 GTA
I used 1/2" and just screwed into my carpet. You could probably get away with 3/4". If you're feeling adventurous you can do what I did with the first amp I mounted back there: pull the carpet up, stick a piece of wood under there, and then screw through the carpet into the wood. I guarantee that the amp won't go anywhere like that.
Old May 3, 2006 | 11:23 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Enough padding, extra insulation plus thick carpet .. in my case the amp stays simply because everything is so thick and the screws just dig in real good.
Gummie's idea's an excellent one though.
Old May 4, 2006 | 12:47 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
if you are putting screws throught the trunk floor above the gas tank figure out where you wnat the holes and get a 1/16 bit. wrap tape around it so only 1/8th inch or less is exposed. (wrap a lot so it has a flat surface so that the bit will not shoot through the completed hole more than the 1/8th or so. slowly srill the hole and when the bit popps through the tape wrapped around it will stop it from going deep. then you can poke a toothpick or something throught the hole to see exactly how muych room you have to work with. Much safer than guessing.
Old May 4, 2006 | 02:43 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
this is my amp rack
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
