Wiring Harness
Old Apr 19, 2006 | 06:00 PM
mhagedon's Avatar
Car: 1986 Iroc-Z
Engine: 406 SBC, alum. heads
Transmission: Built TH700-R4
Axle/Gears: 3.73 posi. Stock :( for now
Wiring Harness
Ok, i bought an '86 Iroc a few weeks ago, and the head unit is gone along with the chevrolet wiring harness. I was planning on rewiring the car with a painless wiring harness since it was made by GM in the eighties.. I'm restoring the car.. So will i need to pick up an '86 harness, or could i use an '89-up (newer style) GM harness? I wouldn't see why not, but then again, i don't know **** about wiring. Man.. I need some help.
Oh, and i cant decide between Black or Silver.. even though it's unrelated, i just cant figure it out.
Old Apr 19, 2006 | 06:09 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Are you talking about rewiring the whole car or just the stereo? If you're talking about the whole car then I would buy the harness for whatever engine you're going to be running: TBI, TPI (speed density or MAF) etc.
Old Apr 20, 2006 | 07:11 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
^^^WHat he said. And Black.
Old Apr 20, 2006 | 08:56 PM
mhagedon's Avatar
Car: 1986 Iroc-Z
No, i'm rewiring the whole car, and im gonna run a 406, no fuel injection. The last time i checked it had a really bad ******* wiring job in the engine compartment, and there's no harness in the dash, just wires.. My last Camaro was Black, it was really Hot, so maybe something different? Black interior for sho.
Old Apr 20, 2006 | 09:24 PM
lockchad's Avatar
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
As far as i know Painless only make engine compartment/ ecm harnesses. What you would need is the BCM harness or body harness which would be a dealer item. Probably more expensive than an Ls1 crate. I know i had to order a harness for a friend who was doing an sr20det swap in his 240sx. He tried it on his own and butchered the body harness. It was $2500 and nobody had it.
As far as the color do black with silver trim/accents.
Old Apr 20, 2006 | 09:31 PM
mhagedon's Avatar
Car: 1986 Iroc-Z
Damn, 2500? Maybe i'll just be replacing the engine harness.. **** I'll i guess i can just sing to myself!
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
