Identifing some wires
Old 04-30-2006, 01:08 AM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
I just need your guys help telling me which wire is negative and which is positive. On the passenger side 4 X 6, it has a clip that plugged into the factory speaker. It was labeled A and B for each of the wires. A is striped green/dark green and B is just solid green. I need to know which is which. And also does the same apply for all the other wires?
For example: The striped is negative, so all the striped wires on the other speaker clips are negative. Thank you so much!
DH
Old 04-30-2006, 09:11 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i think how you just said it is how it is,
another way to find out real quick is to look at one of the speakers and see which wire goes to the cone coil and which goes to the cone only
pos to the coil and neg to the cone material
afaik but then im no audio person
i usually dont worry about it unless it make a noticeable difference in sound, which i dont think it ever has in the past,
its too hard to figure out which is which
good luck
Old 04-30-2006, 12:07 PM
lockchad's Avatar
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
The stripe that you are seeing is just color transfer from the wires pulling apart. Gm factory wires have no stripes in the audio wires.
here ya go....
fr+= lt grn
fr-=dk grn
fl+=tan
fl-=grey
rr+=dkblue
rr-=lt blue
lr+=brown
lr-=yellow
mostly dark in the rear for +. light in the front for -.
Old 05-01-2006, 07:14 PM
Xophertony's Avatar
Car: 1988 Trans-Am GTA
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
here is an image of the wire scheme
Glowsock
01-09-2017 04:06 PM
Caspar
06-19-2016 11:19 PM
ndndndnd
Carburetors
17
09-05-2015 06:24 PM
Bryan F
08-27-2015 07:28 AM
Bert87
08-23-2015 03:50 PM
Quick Reply: Identifing some wires
