ghetto amp rack
Old May 26, 2006 | 12:42 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
ghetto amp rack
i couldnt really figure out any way to make a 20 inch wide 2 foot long rack to go behind the drivers seat and look halfway decent, so i decided to remove both backseats and have the amps on the sloped platform where your back would lean against, side by side, all the way across. i think to get around the curves im going to do 3 layers of mdf, smallest on bottom, then wider as i clear the curves. i want to keep the side trim pieces but im having a hard time figuring out how to securely mount the mdf there to support 20+ pounds worth of amps. any ideas?
Old May 26, 2006 | 11:10 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Brackets of some kind to go from the amp rack to the mounting area for the seat belts ? Assuming you removed the back seat belts. If not, maybe run a brace across the shock towers, and "hinge" the rack on it, resting down against the wall where the seats used to be.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
