Can 6.5 inchers be stuffed into 6x9 rears???
Old Jun 6, 2006 | 08:32 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
A friend just gave me a really nice set of Boston 6.5 speakers. I believe my new to me 88 IROC takes a standard rear set of 6x9's? Can that area be easily modified to accept these Boston's??? (Hopefully this isn't a stupid question)
Nitro
Old Jun 7, 2006 | 09:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's a piece of cake. Build an adapter that bolts into the 6x9 hole, and cut out the right size hole for the new speakers.
Old Jun 7, 2006 | 09:54 AM
neagan's Avatar
speaker install....
Excellent! I thought I'd better get a bit of feedback before I got my hopes up and started taking things apart! Thanks, Nitro
Old Aug 2, 2006 | 11:08 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Jim, what kind of material would you suggest for the adapter? This sounds like something I'd like to do.
Old Aug 3, 2006 | 08:07 AM
Jim85IROC's Avatar
1/2" MDF, 3/8" Masonite, 3/8" ABS or any scrap wood you may have laying around the house. Just toss a little sound deadener on the panel to help absorb resonances and you'll be all set. That whole B-pillar cavity rings like the liberty bell anyway, so any adapter plate you build will be the sturdiest, quietiest part of the whole area anyway.
Old Aug 3, 2006 | 08:44 AM
Bull's Avatar
Engine: LT1; None
Thanks, Jim.
And does a 6.5" speaker always outperform a 6x9, making this swap a worthwhile project?
Old Aug 3, 2006 | 11:46 AM
Jim85IROC's Avatar
Always? No. A very good 6x9 will certainly outperform a low end 6.5". Even within the same product line, in many cases people may prefer the sound of a 6x9 because it'll have a better capability for deeper bass due to the larger size & mass. There are some sweet sounding 6x9s out there.
But, as a general rule, when comparing a 6.5 and a 6x9 of identical materials & construction, you'll find that the 6.5" will usually have a cleaner midrange due to less distortion and better (and more predictable) dispersion characteristics.
The biggest benefit is that by going to a 6.5" size, it opens up a whole new level of quality speakers that simply aren't available in a 6x9" format. Now instead of just low end coaxes, you can choose from high end coaxes and all kinds of component sets.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
zayne0
Aug 24, 2015 07:22 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
