Viper 790XV addons
Old Jun 8, 2006 | 01:07 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
Viper 790XV addons
I am about to purchase a viper 790XV alarm system. I know that they are capable of add ons and I was wondering which ones that you guys think are a must have??
1. Internal Piezo alarm
2. Proximity Sensor ($150 installed)
3. DIE Backup Battery
Im not too sure about the proximity sensor, not sure if it would matter having the t-tops or not...
Old Jun 12, 2006 | 04:02 AM
True's Avatar
Car: '85 Z28
Engine: Need one. =(
for $150 installed? Wow. No wonder so many audio/alarm shops are in business. The unit can be had for $35 or less and doesn't take much to install / tune.
Anyway, I ran a 791XV in my Buick with the shock sensor, 508D (proximity sensor), and the 506T (microphone for glass breakage). I was considering some other things but never did it. Never had any breakins, so I can't tell you how well any of it worked, other than with my playing with it Never got around to finishing my own custom security system...
I will eventually install one of these (maybe without remote start - is that what 790XV is?) in my Camaro, it currently has some super low-end pile DEI... Anyway, to finally answer your question: depending on where your sensor is installed and if you take off your T-Tops enough, a proximity sensor would probably be a good idea. I would think twice (hell, not even consider it) at $150, though.
Old Jun 12, 2006 | 04:15 AM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
Backup battery is a must, that way you know your alarm is working at all times. The piezo siren is only necessary if someone actually gets inside the car. I would do the proximity sensor before a piezo because you can make the sensor go off if someone is too close to your car regardless of t-tops being on or off. Your alarm should come with a hood pin and a wire to connect to the trunk... make sure both of those get hooked up. If you have rims on your car you might want to get a tilt sensor (detects the angle of the car changing as it is being jacked up to steal your wheels and sets off the alarm). Other than that you could get a glass detection microphone in case someone breaks your glass but considering how easy it is to break into our cars w/t-tops I would AT LEAST get the backup battery and proximity sensor.
Old Jun 13, 2006 | 04:49 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Def. get the 530T power window automation modual
I just put one in my car and I love it.
Old Jun 18, 2006 | 09:41 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I've got 5 of the piezo sirens in my truck and some strobes. They may get in, but they will not be happy about being there.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
