So is this any good?
Old Jun 10, 2006 | 11:11 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Scored this outta a camaro in the junkyard today...cant really complain if its good or not for $25
Appears to fit 2 10" subs with mounting hardware for an amp on top.
Is this something homemade or aftermarket bought? How can i tell? And lastly would this worth using or selling on ebay...?
I dont have subs YET. But have been very close to buying a setup and then i came along this today.
Let me know whatcha guys think!
Old Jun 10, 2006 | 11:16 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
somebody made that
Old Jun 11, 2006 | 12:52 AM
crazyryceman's Avatar
Car: '90 Firebird Formula
Engine: 5.7L
ya it does look like someone made it but hey if it works then keep it. $25 is a good deal for a box. if not, just fix it up a lil bit and sell it. people would easily pay $75-$100 for one of those boxes
Old Jun 11, 2006 | 09:26 AM
Stevo's Avatar
what im kinda curious about is like how a sub will fit in well, it fits 10" subs but it looks like the back of the sub would hit the box when placed in?
Old Jun 11, 2006 | 12:12 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
depends on the depth of the sub or how large the magnet is.. many subs will fit into that box, many won't.
to me that box looks home made or a quick box done by a stereo shop.. heck I've seen much worse from 'professional stereo installers'
If you wanted subs this would be a great start, you couldn't buy the wood for what you paid. That would be a great starter box, seriously. Buy the best subs you can afford, and if need be, modify the box; Peel off the carpet and remove the top panel of wood. (Its hard to tell from the pics, but once the top panel is off, I'd cut a divider and secure it into the middle of the box to create to equal areas of air space) Then cut out a new piece of wood for the top and mount the subs closer together so you have plenty of depth below the magnet. Paint/gelcoat/re-carpet the top and your ready to go (other then wiring an amp/crossover). volia.
At least, thats what I'd do if I had that box sitting in front of me..
Old Jun 11, 2006 | 02:18 PM
Engine: 5.7L
it should really be a problem with 10's. not too many 10" subs have that big of a magnet. if the box was made for 12's or 15's then ya it would be a problem.
Old Jun 11, 2006 | 02:25 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i built a box that was similar to that with the sides being shallow and when i tried to put my 12" L5 in it hit the bottom of the wood so i had to modify and make up for the 2 extra inches is stuck out
Old Jun 11, 2006 | 02:30 PM
Engine: 5.7L
i hate when i make mistakes like that but theyre always fun to look back and laugh at your own stupidity
Old Jun 11, 2006 | 02:56 PM
alpine247's Avatar
Car: 1988 IROC-Z
maby the box was built for the sub magnet facing outwards
Old Jun 11, 2006 | 02:59 PM
Engine: 5.7L
maybe but wouldnt the magnet hit the glass? whats the point of that anyways? ive always wondered about that. does it make it hit harder or something?
Old Jun 11, 2006 | 07:58 PM
drlivingston's Avatar
You can make that box work for two 12's and you won't have to invert the subs. Just peel away the existing fabric and reupholster the box. There doesn't appear to be any rotting so it should hold up to pressure. Depending on the subs, you may want to add a slot port to vent the coils.
Old Jun 11, 2006 | 10:12 PM
Stevo's Avatar
thanks guys Good advice.
Old Jun 11, 2006 | 10:37 PM
1985 russetbird's Avatar
Car: 1985 Trans Am
Engine: 305 tpi
looks much better than my box, and hey if you cant fit what you want into it you can easily turn around and sell it for 50+
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
