Need Major Help with New Subs
Old Jun 16, 2006 | 09:33 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Our setup consist of a kenwood unit with a 2x520 amp. In the back with have 2 JL 10w-3 4 ohm DVC's Anytime the radio is turned up or the bass boost it kicked on , on the amp, the light turns red, then to green kicking the subs on , then back to red , then back to green. What would cause this? Also we also had it one time where the subs acted up and literally came up 3 inches and scared the $hit out of me. It was like a massive surge. We are running 4G from an Optima to a splitter then an 8g 2 feet to the amp. Any suggs?
Old Jun 16, 2006 | 10:29 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
Turn your gain control down on the amp because it sounds like your amp is clipping. See if that fixes the problem, if so then you know that the gain cannot be turned up any higher or it exceeds the limits of the amp's capability.
Old Jun 16, 2006 | 10:37 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
heres a great link for setting the gains if your interested.
JL Audio
Old Jun 19, 2006 | 02:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Problem is fixed. I had a bad ground. Thanks for you help guys. The car sounds bada$$ now.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
meeklay812
Oct 1, 2015 03:46 PM
