2 12" Subs
Old Jun 29, 2006 | 12:42 AM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
2 12" Subs
I finally got around to doing it. It dose sound better then my old set up here.This is tempoary till I figure out what I want to do for a box. But I kinda of like them there. It dosen't sound that bad. It's GOING to need a box though if I want it to sound really good. Plus I need to get the amp adjusted. But in all. It's not that bad. I screwed up on the board though. I'll probaly make a new one and carpet it and do some other things to it till I get around to a box. The subs are Alpine type-e 12" and the amp is an Alpine mrp-m350 amp. So let me know what you guys think. Adam :-)
Old Jun 29, 2006 | 10:23 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
youre probably going to hear a thousand tmes plates suck, but as long as it's temporary, looks good for now. nice install and clean interior
Old Jun 29, 2006 | 01:01 PM
The plate is only for now. It was the fastest and cheapest way to get them in the car. I have plans for a box. Just got to get the money and time to do it. Adam :-)
Old Jun 29, 2006 | 01:04 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
the plans for a sub box can be found here
https://www.thirdgen.org/forums/car-...-done-now.html This is what i plan to do
Old Jun 29, 2006 | 01:52 PM
Done allready printed out the plans and thinking about it. Adam :-)
Old Jun 29, 2006 | 04:14 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I've had better luck with two 12" subs isobaric on a board across the well in the bottom. AAMOF, I hit 135.5 dB with just one of them the day after I blew one while trying to get ready for the dB Drag contest.
Old Jun 29, 2006 | 06:03 PM
I'm not really into the loud system db drag things. I just want a system that sounds clear and has some bottom end. The only resson I went with this stuff is because I got it from my brother. He's having another kid and needs the trunk space. And I just used the board because it was the cheapest way to get them mounted in the car. They do sound good like they are though. It's better then what I had. i just need to get a set of speakers for the front and rear. Adam :-)
Old Jun 29, 2006 | 10:24 PM
AJ_92RS's Avatar
I'm not saying you need to shoot for SPL either.
I'm saying that the seal I got from putting them in the lower well was much better than resting them up top like you have them. That was my point.
And the better seal you have, the better they will sound. Doing it the way I did won't cost you any more than what you did.
Old Jun 29, 2006 | 10:36 PM
OK. I see what your saying. You put it lower down in the well instead of like the hinge thing I did up top. I get it now. Adam :-)
Old Jun 30, 2006 | 07:16 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Plates suck.
Sorry, had to.
Old Jul 1, 2006 | 12:31 AM
Originally Posted by Jim85IROC
Plates suck.
Sorry, had to.
Well then you suck! lol. J/K.
I need to get a box though. I was out at a show tonight with my car club. We started comparing are subs. I have the biggest out of all of them. But it hit's the softest. lol. They have like a old crappy 10" sub in a sealed box. I felt like a supped up Camaro owner that lost a race to a Honda. lol. Adam :-)
Old Jul 1, 2006 | 11:42 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
cool grills, almost look like rims! where'd you get'em?
Old Jul 1, 2006 | 11:55 AM
***** Central aka Pepboys. lol. They kinda match the rims I have on the car now. I didn't plan it that way it just happened. Kinda neat I think. Adam :-)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
