Memory Power Problem
Old Jul 7, 2006 | 09:50 PM
Frantic370's Avatar
Car: '91 Pontiac Formula w T-Tops
Engine: 5.0 V8
Transmission: AT
I bought my 91 Camaro Rs this past year in Sept. One of the first things I did after getting it road worthy, was install a stereo. I know most wires are hooked up right, all except for the two for power: One hot, one not. I couldnt get my stereo to turn on at first, but then a friend of mine taped all four wires together (2 from car, 2 from deck). My stereo powers on when my car is on, but it has no memory. It cant remember the time, track, anything. I was stumped. ANY help is appreciated.
BTW to know what wires were which I used a Haynes repair manual
Old Jul 7, 2006 | 10:05 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
ok, first... UNTAPE THOSE WIRES!
you need to use a volt meter to find which one is hot at all times. this goes to your CONSTANT 12V power wire on the HU.
Now with your ignition ON find another wire that is hot. kill the ignition and see if it looses power. If so this goes to your SWITCHED 12V on the HU.
in the factory wiring for the car, looks like YELLOW is the switched, and ORANGE is the constant. I normally run new wires, but if you want to use the factory ones that looks like it for ya.
any more help or confusion needed, post again.
Old Jul 7, 2006 | 11:11 PM
robmonte's Avatar
Car: 84 Z-28 HO
I agree, Orange(in car)=constant(yellow on most radios) and yellow(in car)=battery/switched/ignition(red on most radios)
simple, cheap, test lights are very handy when it comes to jobs like this
Old Jul 8, 2006 | 04:03 PM
Frantic370's Avatar
Engine: 5.0 V8
Transmission: AT
I seem to remember testing wires. Orange is the constant, but for some reason when everything was hooked up right, the deck didnt turn on. But ill retest to be sure and get back to ya. Thanks.
Old Jul 9, 2006 | 07:11 PM
Frantic370's Avatar
Engine: 5.0 V8
Transmission: AT
I think it might have something to do with my ACC fuse. Its been shorting out for a while now and I can't seem to find it. Once I find it once and for all ill see if that works and I'll give some feedback.
Old Jul 11, 2006 | 05:26 PM
robmonte's Avatar
Car: 84 Z-28 HO
If you keep blowing fuses take a few minutes and disconect the battery before messing with the wires, or atleast hook up a good ground first. You could always disconect the harness from the radio then do all your wiring and plug the radio in last
jhawkeye
May 25, 2022 06:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
ZsTransAm
Aug 11, 2015 07:30 PM
