12 inch box???
Old Aug 6, 2006 | 09:54 PM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
12 inch box???
i m going to build a box for my hatch.... nothing to big i still want trunk space.. after all the box is only going to house 1 12 in sub (sony xplod) what i wanna know is will a sub hit better with less space in a box or more space and is an air tube gonnamake that big a difference?????
Old Aug 6, 2006 | 10:13 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
the sub should have box specs, you dont want it to big or to small. plus it all depends on if its ported or not.
Old Aug 6, 2006 | 10:19 PM
85T/A's Avatar
whats ported lol.. i dont dont know jack abput aduiod systems lol
Old Aug 7, 2006 | 03:27 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Check out this site Car Alarm, Car Stereo, and Cruise Control Info for Installers
Look around on it, it shows you all of the different box types, and has calcs that will figure the volume and such. If you want trunk space, a sealed box will be the smallest, and the easiest to make, and make it sound good.
Heres what I did, but with 2 12's. You could do the samething, but just half of the box, to have some space. If you have the wood wooking skills, you could build one in the storage compartment. Try a search on the site, there are quite a few pics of sub set ups to get you an idea.
Im going to fiberglass the spare tire area and mount in a 12" L7 in the future. Currently Im running that box in the pic, but cut down to 1 sub, cut the sides/top, and left the whole bottom in place. About the onlything I use in the back is storage for my helmet, and the storage area for all of my fluilds/funnels/jumpercables.
Old Aug 7, 2006 | 09:59 AM
85T/A's Avatar
i found that i need 1 cubic foot and it didnt say anything about being ported..... soo now what just build the box... and cut a 12 in hole in the top or what... i feel dumb
Old Aug 7, 2006 | 12:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Just stick it in a 1.25 cubic foot sealed box and be done with it. If you're not familiar enough with it to know what a ported box is, you'll never get one to sound right anyway, so stick with sealed.
The sub calls for 1 cubic foot, but going a hair bigger than the manufacturer recommends, especially on cheap subs, is almost always a good idea. "Small box" subs are so popular now, that a lot of manufacturers fib a little bit when recommending a box, especially on entry-level subs because generally small-box subs are very inefficient, which means they need a ton of power to get loud. Well, cheap subs tend not to handle high power, so the manufacturers usually make them more efficient, which means they aren't going to work as well in smaller enclosures.
Old Aug 7, 2006 | 01:17 PM
85T/A's Avatar
so what exactly do i have if ive got an 800 watt 2 channel amp from power accustics.. i know what two channel is and all that but what kinda quality should i expect from it I M Buying it for 40 bucks off of a friend of the family
itll be pushing like i said a 12 in sony xplod 900 wat max....
is the amp cheaply made is the sub cheaply made... are they good... i got the sub for free.. it was a gift
any help greatly apprecited..... thanks for the tip with the 1.25 cubic inch box
Old Aug 8, 2006 | 01:54 PM
Car: 87 Firebird
Engine: 5.3 76mm
You will get base, thats for sure, will it sound as well as a well put together system, no. But having a sub is better than nothing at all in these cars when you keep the stock location speakers.
Build it, and try it out. You can always go better latter once you learn a bit more, and get a feel for it. Just remember to use 3/4"MDF. Its $25 for a 8x4ft sheet at most hardware stores. Get some 1.5" or 2" screws, and some liquid nails and stick it together, put a screw every 3-4", predrill to keep the wood from splitting.
Old Aug 8, 2006 | 09:11 PM
85T/A's Avatar
yeah man thanx.... i know alot about working with wood too.... my dad was a carpenter all his life so i got the knack of woodworking in my blood lol so yeah thanx for the help.. i didnt know what i needed or how to build a box in particular... so really Thanx
Old Aug 8, 2006 | 10:26 PM
Iroc_man's Avatar
Car: 87 Iroc
i hate to tell u this, but that sub is not the good, at all. the amp is probably 350-400 watts RMS bridged, it isnt 800 RMS its probably max, my friend had a power acoustics amp, they are considered flee-market brands, or cheap brands. but if you are looking for a little bump and dont really care about SPL or SQ, then be my guest and go with it, but if u are like me, and care about spl and sq, then get something better. also, a sub needs to have a box that is closest to its specs, for example, if you put that sony explod in a 20 ft cu ft sealed box, obviously it wont sound good, but if its more like 2.3 or 3 cu ft, it will be better. so it all depends on if its a ported or sealed box, and also depends on the sub.
and yes i agree with jim, since you dont know much about car audio box's, go with a small sealed box, because a ported box needs to be tuned to the right Hz.
Old Aug 8, 2006 | 11:33 PM
85T/A's Avatar
well.. not ttrying to be rude or anything... really i m not. but i dont know what those 2 things you mentioned are.. i just want a lil sumtin to here because i had an 8 in" JL and a 250 Bluapunkt amp that shook my car ... i could have my car on and idleing and when the bass hit i could feel it in my shifter... i m not lookin for anything crazy jsut somethin to have.. i got used to havin a sub and then kinda got screwed outta it... i was going to buy 2 12 in Visonics in a box for a Hundred bucks so i sold my jl and amp to get them and then guy changed his mind overnight.... literally any way... i just want a lil sumtin.. i mean its not gonna sound like **** tho is it?????? i know Xplods aint the best and i prolly wouldnt buy one normally but i got it for free and my dad is buying the amp off a freind of the family.... wow didnt expect to write that much
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
buckshot63
Sep 10, 2015 09:15 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
