constant hot probs
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
constant hot probs
I was just installing my sony HU. I had everything working great. I did not hook up the wire for my amp right. so I went to make sure I was on the acc wire and I had been checking the constant wire when I saw a small spark and then heard a pop. now there is no more constant hot. I have checked the fuses and they were all good. I am now stumped. where does the constant hot wire connect to? as in where in the car. thanks for any help.
Car: 1989 RS Camaro
never mind I found there is another fuse panel that I did not see before.
