Remove stock antenna connector?
Old 09-03-2006, 09:18 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
I'm putting a Kenwood deck unit in my wife's 92 Z/28 and the stock male doesn't seem to fit well in the Kenwood female connector. Is it ok to cut them both off and just use regular male/female wire connectors?
Jeff
Old 09-03-2006, 09:31 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Scoshe actually offers an adapter kit to fit the antenna to aftermarket radios, it just plugs into your antenna and then into the radio.
I think it's available at Walmart or online.
Trying to wire up another solution is tricky because the wire in the antenna lead is very thin.
Old 09-03-2006, 09:32 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
You will probably need an adapter. The older antenna cables were a bit bigger than the ones of today.
Old 09-03-2006, 10:03 PM
thaforce's Avatar
Car: '91 Z-28 Hardtop
Engine: 5.7L TPI L98
He probably has the smaller GM adaptor, most of the car stereos today still come with the larger antenna jack.
You should be able to snag an adaptor at Wallyworld, Advance or Auto Zone.
Old 09-04-2006, 09:35 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
Wow,
My car has the old big antenna, (course, it's an 84...) and the radio has the smaller jack.
Old 09-26-2007, 11:00 PM
87-4MULA's Avatar
Car: 1987 Firebird Formula
Re: Remove stock antenna connector?
yea i ran across the same problem today with my 87. im trying to put a stereo out of a 99 grand am into mine and noticed that the antenna jacks are not the same. Im going to look into an adapter. if anyone knows which one i need or wheres the best place to get one, drop me a line.
Old 09-27-2007, 07:40 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
GM changed to a smaller antenna plug sometime in the early '90s.And just about all aftermarket radios come with the smaller antenna jack(industry standard for several years).As stated you can pick one up at just about any electronics store,automotive parts store ordepartment stores that sell automotive stereo equipment.hope these numbers help.Check http://www.crutchfield.com to find exactly what you need but you can probably find it locally to you.
Metra P/N AW-GM20(aftermarket receiver to original factory antenna)The GM20 part is generally found as part of the number no matter the maker of the adaptor.
Metra P/N AW-GM21(adapts '91 up GM radio/aftermarket to earlier antenna leads)
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
perZ
08-15-2015 01:17 PM
Spd-Kilz
Interior Parts Wanted
08-15-2015 12:12 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Remove stock antenna connector?
