Subwoofer repair
Old Sep 7, 2006 | 03:16 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
Subwoofer repair
My 12" sub has developed a rip in the foam outer ring. Its not a tear that I could glue it together to keep it from spreading, some pieces did fall off. Its like a gash thats about 2"x1/8". Is there a way to fix it? I love my JL and I don't throw it away.
Thanx!
Old Sep 7, 2006 | 03:30 PM
Rydda's Avatar
Car: 89 Camaro, 93 Cadillac Deville,
Engine: 355 in the camaro, 4.9 in the caddi
Transmission: 700R4 in the camaro
Axle/Gears: stock on both
yes you can, but it looks ****ty as hell and wont hold up long. if your despirate you can use some silicon caulk. it will hold it together and it flexes. but like anything else if it flexes too much it will break, or come undone in this instance. your best bet it so junk the sub and go get a new one
Old Sep 7, 2006 | 03:32 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Many places sell refoam kits. I've refoamed a few woofers, and if you take your time it's not really too hard.
This is where I buy mine from:
Speaker Parts - Newfoam, Speaker Repair, Speaker Parts, Speaker Foam, Replacement Speakers
The site is hoakey, but the business is a storefront business in Rochester NY that's been there for years. I was there very often when I was in college, and I still make sure to stop in from time to time when I'm in the area. The owner, though he assumes everybody is speaker-stupid, is extremely knowledgable and helpful. Though when I used to deal with audio-noobs on a daily basis, I used to treat them all like they were stupid too
His kits will come with the new foam, new dust caps, voice coil shims, and glue.
What you do is cut the dust cap off the woofer so that you can access the voice coil. You jam the shims into the voice coil gap to ensure that it stays centered when you remove the rest of the foam. Once the foam is completely removed, you glue in the new one. Once the glue dries, you can remove the voice coil shims, then glue the new dust cap on. It's time consuming, but pretty easy.
Old Sep 8, 2006 | 01:44 PM
thaforce's Avatar
Car: '91 Z-28 Hardtop
Engine: 5.7L TPI L98
You can send that woofer to JL and have it reconed for a flat rate, and it will be just like new.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
