Having a problem with my CD player
Old Sep 24, 2006 | 11:24 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Hey guys, I've been having a problem with my CD player lately. Whenever I put the volume past around 25, this is when a CD is being used, the song will play a little, then theres a pause, then it plays again, then a pause and it continues on and on until I lower the volume. Does anyone have and ideas as to what might be wrong?
Old Sep 24, 2006 | 11:32 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Could it maybe not be getting enougfh power? Past a certain volume, it crosses the bridge between just barely and not enough, so it dies while the battery catches up?
I dunno, strange. You could try a better alternator, but that's an expensive theory if you don't just have one laying around. Which, I kinda doubt you do.
Old Sep 24, 2006 | 11:46 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
It does sound like a voltage issue. Are you running any amps?
Old Sep 25, 2006 | 05:15 PM
rjpbboi's Avatar
No I'm not. And I'm feeling rather embarrased that I never thought of the alternator especially after I told my friend to get a better alternator after he got subs for his truck. Thanks for the replies guys.
Old Sep 25, 2006 | 08:28 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Check your ground if you're running an amp. If you have a bad ground, or if the ground wire is on a painted or rusted surface, it will cut out exactly like you are describing.
Old Sep 25, 2006 | 10:32 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
What's the make and model? Are the display lights dimming? Do you have a DMM (Digital Multi Meter) and know how to use it?
Old Sep 25, 2006 | 11:28 PM
Gummie's Avatar
Car: 88 GTA
I wouldn't point a finger at the alternator yet. I would be amazed if the 5 amps a deck could pull are enough to make your car’s voltage drop. You should check voltage at the deck when it's going full tilt (or close to it). If it’s dropping too low (below 10 or even 12 volts) that would explain your problem. You might also want to shoot NEEDAZ a pm if he doesn't stick his head in here soon - he fixes decks for a living.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
