ramapge amp will it owrk????
Old Dec 5, 2006 | 06:01 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
new rampage bluefinoix 500 watt 4 channel bridgable amp, will it push 2 12's at all or should i not even bother, great price on it tho...brand new
Old Dec 5, 2006 | 06:35 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Rampage is Audiovox brand. Might want to spend a few more pennies for something better. If it is low price it is low qaulity.
Old Dec 6, 2006 | 04:32 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
QFT dont waste your money, save up and do it right the first time, audiovox is garbage, all their stuff is cheap
Old Dec 6, 2006 | 04:44 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
If you dont care about quality it all depends on the RMS and max output of the subs. You dont wanna look at the 500 watt part. That is the max of the amp. Each channel is only pushing 125 watts the most and if u bridge you can put out a 2 channell with each pushing out 250 watts. That all ready sounds like a crappy amp. Measure up not that max, but what the amp pushes with RMS power, also, do it right, buy at the most a 2 channel amp if you want a stereo sound in which both woofers are on thier own channel, in which would be good if you like rock, or a mono which both subs are hitting the same, in which you would probably like if u are into rap. All in all, just look at the RMS power outputs and match them up and then also make sure the max output of the amp isnt higher of that of the woofers.
I can tell you know though, unless they are cheap subs, ur amp wont push for the performance you want, you will hear it, but, u wont be impressed.
Old Dec 6, 2006 | 06:29 PM
TheBandit's Avatar
Engine: Poncho 350
^^^ exactly.. just save up man, really pays off in the end, unfortunately i learned the hard way :P but oh well.. i finally got some pretty good stuff and realized i shoulda saved and bought this stuff in teh first place
Old Dec 7, 2006 | 05:55 PM
Charged350's Avatar
Car: 87 IROC Z28
savin up is not the issue, its that this deal came accross and i wanted to kno if it was any good, since its not ill pass on it, thanx for da help fellas
Old Dec 15, 2006 | 11:18 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
On a Rampage, take off a zero or two; that's the real wattage rating...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
