6.5's?
Old Dec 6, 2006 | 07:07 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
6.5's?
I want to get another set of components, will 6.5's fit in the sail panels?
Old Dec 7, 2006 | 03:25 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
you will have to make an adapter plate to mount them in, but yes you can fit them. I used 1/4 inch MDF cut it the size of the hole and blted it in, then cut holes for both my 6.5" woofers and .75" tweeters.
Old Dec 7, 2006 | 09:01 AM
cub and Matt's Avatar
What we did was use 1/4" masonite. Its very stiff. We make a plate that fills in the 6X9 space. Also what you can do to improve the sound is (DISCLAMER!!! Be very careful!!!) use triple expanding foam to build an enclosure. I use duct tape to give me the rough size then foam it in. It reduces rattles and tightens up the midbass significantly. Again be very careful with Triple expanding foam. It really does expand. If you use too much you can bubble out your outside sheet metal. I do it in small amounts.
Old Dec 8, 2006 | 06:37 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Im thinking about putting the MB Quart QSD216's in there, wondering if any has them and what they thought.
Old Dec 10, 2006 | 07:55 AM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
don't know about the mb Quart but I do know that the Polk kappa's absolutely scream and have a real tight mid bass. Never thought of using masonite...did you cut it with a rotozip or what cause it has a tendency to crack doesn't it..
Old Dec 12, 2006 | 10:27 AM
No it doesn't crack. Masonite is a tempered fiberboard product. I use a jigsaw with a fine tooth blade for smooth cuts. Very easy to work with. Seals well with silicone. Lightweight as well. I also believe that with comparable thickness it is stiffer than conventional products like OSB, particle board and even MDF.
Old Dec 12, 2006 | 10:33 AM
jmoney843's Avatar
Car: 89 Iroc Z
Engine: 350TPI
I ran a set of the QSD216 6.5 components in my GF's monte carlo, its a very clean sounding speaker and just keeps its clearity as the volume goes up. I used a JL 450/4. I would recomend these if you're looking for a good clean sound. They're not as....deep and 'bassy' as some others.
C409
Dec 17, 2016 09:35 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
