Need some ideas..
Old Jan 13, 2007 | 08:29 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Need some ideas..
On where to run the power wire through the firewall, and where to mount the inline fuse for the power wire.
As you all should know, the battery is on the passenger side, where the blower motor is and all of the air conditioner junk is, and no holes in the firewall to pass the power wire through.
And, any suggestions on the best, most easy way to run the RCA's and remote wires are greatly appreciated, also the BEST place to make a ground in the hatch. I currently have a stereo already installed, but it really needs re-wired.
I also need some ideas on a good place to mount my amplifier, where it cannot be seen by a crook. I have thought about cutting a hole in the back of the back seat and putting it in there, but then there would be no air flow and the amp would get hot.
If you guys will, give me plenty of pictures, instructions.. have fun with it.
I also plan to try the Peel and Seal stuff mentioned in another thread, suggestions on where to put this stuff? I was just thinking EVERYWHERE.
Old Jan 14, 2007 | 02:13 AM
AmorgetRS's Avatar
Since I've only done Firebird installs my battery is on the other side. However, the inline fuse needs to be as close to the battery as possible. If the wire grounds before the fuse can cause a fire.
You can mount them in seats, there are tutorials around on that. I ran my RCA cables up the middle to keep them away from the power wire.
I grounded my wire on one of the ridges under the plastic in the rear. Not really sure how to explain it.
Old Jan 14, 2007 | 10:16 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
once i get the ice off my car (might be a few days i guess were getting snow today) i'll see were best buy ran mine when they did it
Old Jan 14, 2007 | 01:39 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
your ECU wireing harness is on the pass side. You should be able to follow it with your power wire. Big hole on the pass fender right beside the heater blower.
Old Jan 14, 2007 | 02:56 PM
Stealthy, can you show me where possibly? I found a huge wiring harness, but no holes to pass anything through. I'm not sure if my car still has that harness though because it was converted to carb and that stuff was taken out, so I may just not be seeing the hole.
Old Jan 14, 2007 | 04:08 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
he is correct this is were mine is running
Fox118
Sep 12, 2015 09:29 PM
3genRS505
Feb 18, 2015 12:49 PM
scamaro355
Alternative Port EFI Intakes
Apr 11, 2014 02:03 PM
KingLee79
Nov 21, 2008 05:00 PM
BOTLFED
Fabrication
Apr 26, 2005 10:37 AM
