Box Dimensions???
Old Jan 30, 2007 | 09:06 AM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Box Dimensions???
Hey...doen anyone know what dimentions would be good for a box that will fit low enough so that i can still close that lid so i can hide the sub and amp and still use my t-top bag?...i know theres a sticky with measurments for a sub encloser but i think it goes above the lip for the top of the box and people talking about folding the seats down for the t-top bag...ide like it to appear stock so to fool thiefs lol...i got a single 13W1V2 sub from JL Audio and an APX1300 Mono amp from Clarion...does anyone have any dimensions???...thanks!...heres a pic...thanks again..
Old Jan 30, 2007 | 09:37 AM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Actually it's about level with the top of the hump.I built mine a little higher at the rear most to tilt the subs forward and also don have t-tops.But if push comes ta shove build da box and just trim a little off the top to recess the top the enclosure to a level ya want then ya can just lay the t's over it and should still be able to use the tie points to hold the bags in place.Not major just bulky and time consumeing but the thump is worth the effort.
Old Jan 30, 2007 | 09:39 AM
ok thanks so i would just take the dimensions in the stiky here and say cut it off a few inchs to lower it?...about how many inchs do you think?..thanks
Old Jan 30, 2007 | 09:43 AM
Bill/T/D/Y's Avatar
here try this...Use the rough dimensions and do a mockup of it in cardboard.Then trim as ya see fit.Keep in mind that the thickness of the wood ya use and the thinness of the cardboard will effect some measurements.Just take yer time and use a ruler.Then enjoy the noize.Mines got a 12" infinity and sounds real nice.
Old Jan 30, 2007 | 09:46 AM
lol alright il try it...although i was hoping for some dimensions i could print off and take to Futureshop and say here build it! lol...thanks
Old Jan 30, 2007 | 09:53 AM
Bill/T/D/Y's Avatar
there IS a post with a pdf file or link there too and one with the dimensions as a picture i think layed out on a single sheet of plywood.
Old Jan 30, 2007 | 10:00 AM
Bill/T/D/Y's Avatar
try this https://www.thirdgen.org/forums/car-...l-sub-box.html
Actually i think it's in this half. https://www.thirdgen.org/forums/car-...sub-box-2.html
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
