Enlarging a 10" box.
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I've got a dual 10" box for the back hatch of the camaro, and it takes up pretty much as much space as a box can take up back there. The problem? I'd like a set of 12's, not 10's. No one seems to want to purchase this box from me, and I was looking at it trying to figure out how I'd cut the holes to 12" from 10". I can't figure out any way that would give any kind of reliability in the long run. Am I screwed?
Car: 1996 Ford F-150 4x4 and 1989 T/A
Engine: 302 in Ford,305 TPI in T/A
Transmission: automatics in both
Axle/Gears: not sure,just got T/A
Before you start cutting up the box you need to make sure it would have enough airspace for the 12's"
Axle/Gears: 3.27 BW
It fills up the entire hatch area. It squeezes just about as much box into that well as physically possible, so I wouldn't get any more space out of a box built for 12's. And any other box I saw would be running them in a small box. Was gonna use filler to simulate a larger box.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Draw out a circle, one inch outward from the current holes, cut the fabric away along the line then get out a saber saw or similar hand held device and cut along the line. That's how I would do it.
Car: 92 trans am clone
Engine: LO3
or take it to a local place if you have one that does custom boxes in shop. if so have them just cut out the extra space cant cost that much takes them like 5 min tops with their tool they have.
Linson
Sep 21, 2015 01:08 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
