Preamp outputs.
Old Feb 23, 2007 | 05:53 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Preamp outputs.
If a headunit only comes with 1 set, im limited to a 2ch amp yes but is there anyway around this? Like anything aftermarket out there to be able to use 2 or 3 sets of pre amp outputs on a headunit that only has 1 set? Or are you **** outta luck and stuck with what ya got?
Old Feb 24, 2007 | 12:12 AM
86TA/MN's Avatar
Car: 86 TransAM
Engine: olds 350 rocket/flowmaster exhaust
Transmission: 700r4/shift kit
Axle/Gears: ???
there r a couple of things u can do either get a cross over or get splitters and turn it into a 2 channel i did it in my old ride its cheap but if you set it up right it will thump,u can buy an x-over where u can input your 1 channel and put out 2 or more for more amps,i still like rockford fosgate,the old school is much better than new
1gta2c
Mar 4, 2007 09:05 PM
Jim85IROC
Car Audio
Dec 8, 2005 08:28 AM
steves86TA
Car Audio
Mar 23, 2004 07:06 PM
MartyMcFly
Car Audio
May 27, 2003 01:45 PM
