berlinetta stereo
Old Mar 15, 2007 | 09:45 PM
vanman84's Avatar
Car: 1984 chevy camaro berlinetta
Engine: 305 5.0
Axle/Gears: stock
berlinetta stereo
what wire kit can i use to hook and amp up to the stock stereo?
Old Mar 16, 2007 | 08:13 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
there is no "kit" for that. You need to use the speaker-level outputs and feed them to the high-level inputs on your amp. If your amp doesn't have those, you need a line output converter that converts the speaker level outputs to RCA.
Old Mar 16, 2007 | 11:46 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Translation = Buy a new headunit
Old Mar 16, 2007 | 12:11 PM
Jim85IROC's Avatar
That's not real easy in a berli unless you can find one of those special mounting kits that replaces the pod with a cradle for a single DIN radio.
Old Mar 20, 2007 | 02:53 PM
fbodyguy86's Avatar
Car: 92 camaro rs
Re: berlinetta stereo
i used to have a berlinetta an i got the line level covertors for it never used them cause i ended up getting rid of the car but that woul be the ideal setup then just run the RCAs back to the amd and the ret is self explanitory
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
rusty vango
Sep 29, 2015 02:44 PM
