running power wire
Old Mar 30, 2007 | 02:49 PM
sloviks88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
running power wire
is there anywhere esle to run the power wire form the bat to the backi have mine in the fender/door opening part n i dont like it i want to no if there is a diiff way to run it...thanks
Old Mar 30, 2007 | 04:11 PM
RSluvr's Avatar
Car: 91RS
Engine: 305 TBI
Axle/Gears: ???
Re: running power wire
You should be able to find a grommet in the firewall and run it through there.
Old Mar 30, 2007 | 04:49 PM
j dezzy's Avatar
Car: 87 TA
That's how I always run wiring from the engine bay.
Old Mar 30, 2007 | 11:26 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
i ran mine with through the hole for the antenna.. just pulled the rubber peice out
Old Mar 31, 2007 | 04:03 AM
82TransAM_45's Avatar
Car: 82 Trans AM
Transmission: th350 turbo
ditto....but watch out for water inside the cabin after that, ducktape or something to cover the rest of the hole...
Old Mar 31, 2007 | 05:07 AM
j dezzy's Avatar
Car: 87 TA
Summit actually makes rubber gromets in all kinds of sizes to put in the firewall to keep it all sealed up. I just saw it in the catalog this month. They're called Seals-it Grommet Seals.
BRoss99
Aug 10, 2025 05:08 PM
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZsTransAm
Aug 11, 2015 07:30 PM
