Aftermarket Speakers in Bose Kick Panels
Old May 27, 2007 | 12:31 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Anyone know of any speakers that fit into the Bose Kick panels. I do not mind if modifiactions are needed as long as I cant tell tis not stock.
Don't tell me about the wirering its not going to a bose head unit.
Old May 27, 2007 | 12:41 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
Re: Aftermarket Speakers in Bose Kick Panels
i have no idea what size speakers are in them , what is it the 4 inchers i think ?
go to http://crutchfield.com and go to there audio selection add in your camaro with boss and they will tell you what will fit and what wont
Old May 27, 2007 | 01:25 PM
crrllmich's Avatar
Engine: L03, LS1
I know where to get 4" speakers just not shallow ones.
Old May 28, 2007 | 10:30 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
I just finished doing this, I had some 5.25 components jammed under my dash and bose kick panels from my last car. The passenger side accepted the mid with very minimal opening of the hole and drilling a hole for the tweeter, I mounted the crossover on top of it. The driver side is shallow so I cut a piece of wood to build it up, sealed it to cover the curve and installed the speaker. The nice thing is that it does not take up as much room as other kicks I've seen and sounds good. I will post some pics tommorrow.
Old May 29, 2007 | 11:06 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
Here are the pictures. The driver side crossover fit on the top inside of the kick panel. I still need some grills and a little more carpet but overall I am happy. The panels were red that I sprayed with some black Krylon fusion. You could speaker cloth over all of it to make it more 'stealth.'
Attached Thumbnails Aftermarket Speakers in Bose Kick Panels-kick-driver.jpg   Aftermarket Speakers in Bose Kick Panels-kick-pass.jpg
Old Nov 6, 2007 | 07:24 AM
crrllmich's Avatar
Engine: L03, LS1
Any updates on this?
Old Nov 9, 2007 | 07:28 AM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
There are a couple of things I noticed about this set up.
1. The kicks need an amp. When they same speakers were under the dash the deck was enough. I only have one amp for the sub. I wired up the kicks to the amp and it was loud enough. I didn't have any bass so I switched it back.
2. They sound 'boomy'. I just last night tried putting in some poly fill to take that away to no avail. The bose enclosures look like they are designed to move air around the back and it makes it sound poor when turned up, even with the amp on it.
I think better equipment would help and sealing the ports, which I might try next.
Old Dec 11, 2007 | 05:18 PM
crrllmich's Avatar
Engine: L03, LS1
Anyone figure out what 4" speakers are shallow enough to fit?
Old Dec 11, 2007 | 05:36 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I doubt you'll find any that will fit without some modification, at least any that are worth the effort to install. I got a 4" Kicker installed inside the passenger side using a dremel, but had to cut and install from the outside on the driver's side. Then re-covered with carpet.
Old Dec 11, 2007 | 05:40 PM
crrllmich's Avatar
Engine: L03, LS1
I dont mind moding as long as it appears stock.
So anyone found a speaker that they could make work?
Old Dec 11, 2007 | 08:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The bose speakers on the kickpanels are 3 1/2 or 3 1/4.I dont remember anymore, but i put cerwin vega 3 1/2 inch tweeters.I just wanted more highs in the front to fill the dash area.Plus the CWs are about i 1 1/2 high so they fit with in the encloser with no cutting at all.Also the bose speakers have only 3 mounting points.Unlike aftermarket which have 4.So i had to make little brackets to secure the CWs to the inside of the kickpanel.
Old Dec 11, 2007 | 09:29 PM
crrllmich's Avatar
Engine: L03, LS1
You are the man!
Old Dec 12, 2007 | 06:25 PM
crrllmich's Avatar
Engine: L03, LS1
84 Where can I aquire these speakers?
Old Dec 12, 2007 | 06:32 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I got them on ebay, but they are only tweeters, not full or mid range speakers, just tweeters.
Old Feb 11, 2008 | 12:11 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Crutchfield does not list any speakers that fit the kick panels even when selecting the bose Option.
However, they do sell a bunch of 3 1/2" and 4" speakers. Does any one know the actually depth of the original Bose speakers? And has anyone measure the ohms of Bose speakers, there seems to be some differences.
Old Feb 11, 2008 | 12:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Bose speakers are 1ohm.The mounting depth is about 1.5 in tops.
Old Feb 11, 2008 | 12:28 PM
naf's Avatar
naf
You're not using the Bose head unit so you probably won't want to mess with trying to save the little amps in these kicks. A modern deck will put out more than these baby Bose amps.
You've got the kicks, right? Open one up and have a look. Take it with you to a stereo place. Decide which speaker to put in that BEST fits. You're going to have to cut if you put in anything worthwhile.
Old Apr 4, 2008 | 01:55 PM
crrllmich's Avatar
Engine: L03, LS1
Anybody find speakers that fit yet? I still havnt had any luck.
Old Apr 4, 2008 | 02:31 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
i got a set at my house that will fit and sound amazing they require no modding and they apear stock... got em from a buddy no marking s on em though .....not even gona uses em , just gona throw em away on trash day.
Old Apr 4, 2008 | 03:53 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I installed the infinity 4 inch in the hole and siliconed around them and they sound great. I had the recovered and you cannot tell they are not bose except they sound better. You don't have to have the 5 inch for it to sound good. Mine look stock and I also use infinity 4x6 infinity plates in the dash and the sound up front is awesome. Don't underestimate the smaller speakers. I use all kenwood equipment (new deck and older amps) and infinity speakers. Very happy with my sound. I use 6.5s in the rear bose deck plate. I use the 91-92 bose deck plates since you can use the bigger speakers. The 87-90 bose rear decks use smaller speakers and smaller air boxes.
Old Apr 7, 2008 | 09:42 PM
BMAN90RS's Avatar
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
hey can you provide me with a link to those ones you mentioned for the kicks, the 4 inch infinity's. thanks alot
Old Apr 15, 2008 | 09:36 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I put 3 1/2" Infinity Reference speakers in mine. One side was deep enough to accept the speaker without modification and the other side needed a hole in the back to get the magnet through so it would close. This defeats the sealed box atmosphere and you loose a ton of mid and low notes, however, how much mid and lows does a 3 1/2" speaker put out?
Havn't heard it yet since the car doesn't run but I had these laying around and was not happy with the Bose kicks.
Old Apr 15, 2008 | 09:49 AM
crrllmich's Avatar
Engine: L03, LS1
You just made my day.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
