2 channel amp in 'multi mode'
Old May 28, 2007 | 10:38 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
I have a little Alpine amp that can run two speakers wired normally and run a bridged channel at the same time to the sub. I hooked it up this way but need a way to just send the low end to the sub. Is there an filter I can put in front of the sub? Also, any advice on gain settings? I just don't have any experience.
Old May 29, 2007 | 09:58 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: 2 channel amp in 'multi mode'
Do some reading on running amps in tri-mode. Check out www.bcae1.com and see #53 on the right. You need capacitors in series with the "full range" speakers as passive high pass filters (base blockers) and a coil in series with the subs as a passive low pass filter. You can get these passive tri-mode filters in one package, but I wouldn't. It would take way to long to get into why there are much better ways of doing this.
But I would really just pickup anther amp for the subs.
If funds are low run the subs off the amp and the other speakers off the HU. This is probable a better option then running the amp in tri-mode. Dose the amp have any x-overs?
Old May 29, 2007 | 11:00 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
The head unit only has one pair of RCA outputs. I had the components hooked up to the HU before and with the amp I can turn it up and there is no distortion. Funds are the issue, I have been trying to use what I have and get the best out of it. I will take a look at the links. The amp has a low pass which works across the all the speakers. Thanks.
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
raymondandretti
Sep 27, 2015 06:43 PM
tattmann
Sep 27, 2015 05:20 PM
