Amp trouble
Old Jun 24, 2007 | 04:30 PM
smooth's Avatar
Amp trouble
I have an Alpine 3552 running my front end and a Jl for the subs I've had my
Alpine for the better half of 10 yrs. This past week it started to cut out after running for 15 minutes or so. They both sit in the well under my box, the Alpine can just about cook an egg heat wise and the JL is cool to the touch. So here is my question will moving the amp above the fuel tank give enough cooling considering it's age?? or has this amp run its life?? I've always had my amps under my subs with no trouble till last week. Second question: If I have to replace my Alpine I've forgotten the power ratings of the 3552 so could some one refresh my memory on what it puts out. I run 2 way seperates in the dash, 6 inches in the doors and 6x9s in the pillars off that amp.
Old Jun 24, 2007 | 04:56 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Re: Amp trouble
I can't give you a definite answer, but I have had similar experience with an Apline amp (MRV-F307). Mine is already sitting on top of the fuel tank. It started cutting out for a while, and now only channels 1 and 4 output anything. I've taken the amp apart and nothing is burnt. I can even run test tones through all the channels while hooked up to a test bench, but in the car channels 2 and 3 just don't work (and I've confirmed the head unit and cables are not the problem). I'm now in the market for a new 4 channel amp.
You can try moving it, but with the sun coming down directly through the hatch window, they still heat up a lot.
Good luck.
Old Jun 25, 2007 | 12:57 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Re: Amp trouble
you've had it for a long time, may just be coming to and end, but at least you got good use out of it.. i would try moving because somethings definitly wrong if its getting that hot, whether its just air circulation or if its crapping out
Old Jun 29, 2007 | 02:33 PM
RSluvr's Avatar
Car: 91RS
Engine: 305 TBI
Axle/Gears: ???
Re: Amp trouble
The 3552's are rated for
30x4 @ 4 ohms
35x4 @ 2 ohms
85x2 @ 4 ohms
I've got 3 of them,still going strong after all these years!
Yep,I'm an old school Alpine guy. LOL!!
BTW if you're gonna trash the 3552,I might be interested in it depending on price. Spare parts ya know. LOL!!!
Old Jun 30, 2007 | 08:21 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: Amp trouble
Heat=To much current. Measure the resistance of all the speakers on the amp. If there all good then it's probably a bias problem IN the amp.
Old Jul 2, 2007 | 12:46 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Re: Amp trouble
Do yourself a favor, and just a get new Alpine.
I just replaced my aging, 2 out of 4 dead channel Alpine amp (the one I mentioned a few posts up) with a new Alpine MRP-F250 4 channel (40 RMS x 4 @ 4 ohms). My subs are louder and my voltage guage doesn't dip below 12 volts like it did with the old amp. I'm now thinking the old amp had a major problem that caused it to pull way too much current. As in although channels 2 and 3 didn't output anything, the channels were still using max current (YIKES). Now that there is more current available for the system, the subs sound MUCH louder.
Definitely get a new amp
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
