db crossfire
Old Jun 28, 2007 | 02:45 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
db crossfire
How good of quality is a db crossfire 12 inch sub. i think it is a 425 watt.
will post a pic of it in a while
Old Jun 28, 2007 | 02:53 PM
Engine: L69 H.O
Re: db crossfire
another quick question how do you set up an amp to just run one sub do the speaker wires go on the side of the amp that says right or the side that says left
Old Jun 28, 2007 | 03:44 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: db crossfire
your amp should tell you how to run it mono right on the amp or have a switch. it most likely will be + on one and - on the other so you are running both outputs. this will change the ohms by half of what the amp runs in 2ch mode.
Old Jun 28, 2007 | 04:34 PM
Engine: L69 H.O
Re: db crossfire
thanks for the help really helped me out thanks. is it normal for there to be a poping noise when i change the track on the cd player or turn up the volume. it all works and plays fine just when i make a change on the cd player it makes a pop.
Old Jun 29, 2007 | 05:26 AM
89N10GTA's Avatar
Car: 1989 GTA
Re: db crossfire
some radios make noises but i can't tell you if it's normal for yours.
Old Jun 29, 2007 | 06:32 PM
Engine: L69 H.O
Re: db crossfire
it only started doing it after i hooked up my sub and amp. the amp is only running one 12 and isnt hook to any other speakers
NZKnight
Oct 15, 2015 02:47 PM
Tweeks25
Sep 17, 2015 08:04 AM
edoff13
Sep 11, 2015 03:55 AM
3rdgenparts
Aug 6, 2015 09:03 AM
