what is the cleanest looking stereo bracket?
Old Jul 24, 2007 | 04:11 PM
theirlaw's Avatar
I have a universal bracket kit from bestkits.com. Is there any bracket available that looks better than this one? Will an audio shop be able to do anything to make the instal look cleaner, more original, or should I just stick with the generic bracket I have?
Old Jul 24, 2007 | 08:13 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
Re: what is the cleanest looking stereo bracket?
Metra makes a 3rd gen specific install kit that flushes the deck back instead of sticking it out about 1-2" like a lot of the kits out there. i did have to modify the vents behind the deck, but i thought it was well worth it. take a look over at sounddomain or on metra's web site for the specific part number
Old Jul 25, 2007 | 05:47 PM
theirlaw's Avatar
I found Metra part number 99-3042 which fits several GM products including third gens. Is this the right one?
Metra 99-3042
Old Jul 25, 2007 | 06:19 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
American international kit: GM-K432
Old Jul 26, 2007 | 01:13 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
Almost completely forgot, but if you got the money (not sure if they have the 3rd gens specifically), but www.humount.com has the nicest GM install kits i've ever seen. Have one in my grand prix now
Old Jul 26, 2007 | 01:51 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Something doesnt look right on that. Maybe its the trim piece.
Old Jul 26, 2007 | 02:02 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The problem is that in order to flush mount a head unit, you need to leave an opening for the face, which is different for every head. The result is that a universal kit has to leave a big gap around the radio. Because of that, when using a regular install kit (as opposed to making my own), I prefer one of the generic styles that adjusts the whole kit in and out, but still mounts the deck face forward of the kit (so that the radio is flush with the faceplate removed). In cases where you wind up with what's pictured above, I like to make a nice ABS trim ring by tracing the shape of the faceplate into the ABS, then cut it out 1/16" or 1/8" large all the way around. After that you can install it temporarily, put the factory console trim back, and trace the outline of that, then cut that out. The result will be a piece that'll completely fill the gap between the faceplate and the console trim for a nice clean, custom flush look.
Old Jul 26, 2007 | 02:27 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
I understand mine's a bit off because it needs some slight adjusting, but that angle shot from the shifter, so its not one you're gonna see and otherwise looks dead-on. it needs to come out again so i can add the steering wheel adapter for the controls, but its not my top priority right now. but even in current state, still looks 100x better than the majority of install kits
Old Jul 26, 2007 | 03:39 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
here is a good clean fit
Old Jul 26, 2007 | 03:43 PM
Jim85IROC's Avatar
It's kind of hard to tell when you zoom in so far that you can't see the mount around the radio.
Here's the deck in my IROC. I still need to find time to move it back another 1/4", but this is probably good enough until I swap in a different head:
Old Jul 26, 2007 | 04:14 PM
here is a better pic now i know that you dont want it to stick out but this looks like it belongs.
Old Jul 26, 2007 | 04:48 PM
Jim85IROC's Avatar
With a GTA digital dash, a camaro console and no other woodgrain in sight, I'm not sure what would "belong" around the radio in your particular case. Even though it's not stock, I always try to make my audio installations look as stock appearing as possible.
Old Jul 26, 2007 | 06:02 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yeah, not trying to be too mean, but that last one does not look at all like it belongs. the stock radio sat back from the trim ring, that one sticks up like it was added afterwards. i had done something similar to jim when i had the same deck (I think we both bought our decks around the same time, great deal when crutchfield had them on sale), but used a decent camaro-specific one i picked up from sounddomain. Its not quite a slick as Jim's setup, but a good compromise between time/effort/money
Old Jul 28, 2007 | 07:41 PM
Car: '88 GTA
Engine: L-98
Errr, belongs to what? LOL J/K
Old Jul 29, 2007 | 09:52 AM
cheppibear's Avatar
Car: 1984 T/A
Engine: Chevrolet 355
Transmission: Borg Warner
Read my mind. This is what I have planned out for my install.
I am going to 1.) Use one sheet of plexi to mount the radio to the pod, and 2) Use another for the radio trim cover. The inner / outer edges of the radio trim cover will be routed for a detailed look. I will be either be spraying the back of the plexi (not sure of the color yet) leaving the front alone, or frosting the back by sanding and adding a light.
Old Sep 29, 2010 | 03:50 AM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Wow i really like the extra mount with the Tv, was that custom made? Or is it a part you can actually buy?
Old Sep 29, 2010 | 05:09 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Definitely looks to me like he bought another 3rdgen radio console and cut it up, and placed atop the original...for a very nice design. I like it.
Old Sep 29, 2010 | 08:48 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
wow, i thought those pics had long disappeared, but I'm sure Jim can fill ya in. That was a custom project he did some years back. Looks very factory, and IIRC, he did buy another radio bezel to modify for the screen
funny to see my old username too (CAMp3RO)
Old Sep 29, 2010 | 12:34 PM
Jim85IROC's Avatar
That mount for the monitor was a custom made deal. I bought a spare console & trim piece and modified the hell out of them to make it work. I also bought an entire spare dash board so that I could harvest some of the flat ABS plastic from the passenger side in order to make the cover piece for the monitor:
Here's the info on how I made this:
http://www.cardomain.com/ride/631053/2
Someday when I get the time and ambition to change the head unit to one to one that's got a built-in DVD player, I'll harvest the plastic from another dash to make a new head unit trim plate and another plate to cover the area where the DVD player currently resides... which will probably wind up becoming a gauge pod of some sort.
Old Sep 29, 2010 | 12:50 PM
Slash's Avatar
damn nice man
Old Oct 11, 2010 | 11:38 AM
levin cris's Avatar
Your can pick one up at walmart or just buy one online or at best buy basically anyplace that sells car stereos should have it
Old Nov 28, 2010 | 05:26 PM
squibbles's Avatar
Car: 1985 firebird
Engine: v6
Transmission: turbo auto
Axle/Gears: ?hellifiknow?
how much would you want if you could make one for me, just the monitor case?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
