Headunit help (pretty sure its toast)
Old Sep 4, 2007 | 02:48 AM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
Weeeeell long story short I was at my cars first show this past weekend aaannnddd I had my stereo on for quite a while, everything was going great, until, get this, I closed my door a little hard and the cd skipped...no big deal right? WELL I got in the car and reset the song and then.....NOTHING, stereo shut off, so..checked the fuses, all good, checked my power and grounds, all good, I have to hit the reset button on the stereo before it will turn on. But once it dose, I have to have the internal amp off or else it will just die again. and im not getting any sound, except though my subs.
BTW my headunit is a kenwood kdc-mp428
thanks
Old Sep 5, 2007 | 06:26 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: Headunit help (pretty sure its toast)
Check the connections to the speakers on the rear of the head unit.
Old Sep 5, 2007 | 07:01 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If it started with closing the door, check all the speaker wires. How did you make the connections? Could be a bad connection on the ground or B+, could be a speaker wire shoring to ground.
Old Sep 6, 2007 | 01:57 AM
Engine: 305 V8
Transmission: auto
And that would suck, I checked all my wires when i installed it >_< guess I gotta pop the dash...and numerous other panels to check the wires.
Any idea how I can check the wires for a short, instead of uncovering them all?
Old Sep 6, 2007 | 01:55 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
Well, you can just pull the head unit and check the connections there. Then pop the rear speakers out and check those (only sail panels come off). In the front, you'll have to take the dash pad off to check the fronts, but that's about it. Wires shouldn't be an issue, unless somehow they got pinched, but that's hard to believe.
Old Sep 24, 2007 | 12:05 AM
Engine: 305 V8
Transmission: auto
WELL....I checked all the wires, none are grounding out, both front speakers are blowen, the they were both a pos anyways, so I re-connected them all, and now it works again >_< but now I cant turn the stero over 27/32 without the stero cutting out (wont turn back on till I turn it back down)
Old Sep 24, 2007 | 01:09 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Leave any blown speaker disconnected until its replaced. An aftermarket deck will go into protect to keep from overheating from the low impedence of a blown voice coil.
Galaxie500XL
Feb 1, 2020 04:53 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
ramicio
Sep 28, 2015 01:18 PM
J.C. Denton
Sep 21, 2015 04:23 PM
