sub box idea.... opinions?
Old Sep 11, 2007 | 10:16 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
ok first i should explain my idea i guess this is a poorly drawn cutaway of the trunk the green is a port the blue is the car and the black is subs side by side(i have two 12") and the red is the box and the gray is amps will this work or is the shape to weird to function?and will the ports function?
Old Sep 12, 2007 | 10:39 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: sub box idea.... opinions?
I think it will need to be ported because it wont be as thick as you think it will...
Old Sep 12, 2007 | 10:41 PM
Brennan's Avatar
it will be ported that was the green thing i was also thinkng of putting it in the same corner butt horizontal
Old Sep 13, 2007 | 09:51 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
air doesn't care about shape, as long as you have adequate airflow around the sub to keep from killing the voice coil (all the extra cooling is useless if there isn't some space around it)
Old Sep 13, 2007 | 12:36 PM
Brennan's Avatar
thank you that is exactly the response i was looking for
Old Sep 13, 2007 | 01:52 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
interesting idea.. you'd have to go with a shallow mount driver(s) by the looks of it. good luck and post pics if you go through with it.
Old Sep 13, 2007 | 01:55 PM
Brennan's Avatar
the picture is only a rough there may be many modifications to fit the subs i already have i think there mounting depth is 6 1/2" so the box will probably be around 8 or 9 inchs thick
Old Sep 13, 2007 | 02:16 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
you wont need a shallow mount sub i had a 15 behind my seats.. its the same idea you have.. but it was in the well and on the hump.. my 15 needs 9 or 10 inches of depth to mount and i fit it fine
Old Sep 13, 2007 | 03:33 PM
Brennan's Avatar
do you have any pictures that i can use for refrence and is it ported and how do it sound??
$750 L98
Feb 1, 2025 02:25 PM
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
Dragonsys
Sep 25, 2015 03:51 PM
Jlanz55
Sep 8, 2015 11:28 PM
