Single 12 ported well box
Old Dec 22, 2007 | 08:21 AM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I was wondering if anyone had a sub box in their well that only really took up half of the space. If so I would like to know if you have the dimensions of the box.
Old Dec 22, 2007 | 10:44 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: Single 12 ported well box
I have one for a 10in JL W3 that only takes up half the well space, it's sitting right next to my nitrous bottle. The dimensions were oddly enough the JL recommended specs for a vented enclosure in the older (2005) W3 manual.
Old Dec 23, 2007 | 09:20 AM
do you have pictures of it??? I have my nitrous bottle down there too and wanted to work that into it as well.
Old Dec 23, 2007 | 11:45 AM
Yes I'll get some pics of it soon.
Old Dec 23, 2007 | 11:50 AM
This was slapped together to get the car ready for King of the Street this year, the wiring to the amp is usually tucked behind the carpet and the back plastic DOES fit with all of that in there. This sub is very loud and clean sounding with the Punch 300S running it bridged running in series (sub is dual 2 ohm for a 4ohm total load). it's all running from a pretty base model Pioneer deck.
Attached Thumbnails Single 12 ported well box-l_46ff58da2bca807760481d43e1de2fbe.jpg   Single 12 ported well box-l_afdb39e53a9d4b4bb167603437d45296.jpg
Old Dec 23, 2007 | 12:16 PM
What are the dimensions for that box.... do you happen to know what the airspace is??? and size of the port???
Old Jan 11, 2008 | 04:06 PM
The enclosures dimensions are 16 X 15.5 X 11, it's 1 cubic foot. The port measures 3 X 14in. This enclosure sounds awesome but it got wet AGAIN *this is the second one I've built* and I'm probably going to end up getting rid of it. I highly recommend you bed line whatever box you build for the well.
Old Jan 11, 2008 | 10:20 PM
Awesome! Thank you... I can probably make something like that for my 12 right? Do you know about what dimensions I would need for that?
Old Jan 12, 2008 | 12:24 AM
What kind of 12 is it? What kind of power are you running and what ohm is the woofer?
Old Feb 11, 2008 | 04:49 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Go here
http://www.cardomain.com/ride/2082526/7
It's for a single 10, wouldn't be much bigger for a single 12.
Old Feb 11, 2008 | 07:36 PM
I got that same speaker in a 12 and that is what I want kind of...
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
bubbaz28
Sep 18, 2015 02:09 PM
ericjon262
Sep 11, 2015 06:07 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
