power antenna
Old Dec 26, 2007 | 01:55 AM
TPImoneypit's Avatar
power antenna
Ok, so the power antenna on my '91 GTA hasn't worked since I bought it... didn't work on my '87 either. I really couldn't care less about it working, as long as the radio works. The problem I have is that I just bought a car cover for it and it won't fully cover the car without bending the crap outta the antenna. As I said I never cared about it working, but is there any way I can get it to go down short of replacing the whole assembly? If I can get it down I can just use needle nose pliers to pull it up (how I got it up on my '87) when I need to. Any help appreciated, I'm not trying to poke a hole in the car cover, kinda defeats the purpose.
P.S. The motor runs, I have the wires unplugged from the relay behind the dash; discovered those wires when I did the heater core.
Old Dec 26, 2007 | 02:21 AM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
Re: power antenna
Try using some WD 40 to get ti to move then just pull it up with needle nose. It might work might not cause the antenna is on a motor.
Old Dec 26, 2007 | 03:45 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: power antenna
Before I bought an aftermarket, I just cut the antenna of mine. I never used the radio anyway. What most guys do is get rid of the exterior antenna and buy another regular antenna and lay that one under the front of the dashpad (near the glass) and I heard it gets great reception. I almost did that, but I had already installed my electric one...
Old Dec 26, 2007 | 09:28 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: power antenna
If the motor runs then you could probably get by with the cable repair kit Modern Day Muscle sells
http://www.moderndaymuscle.com/inc/s...tenna&n=568369
I uuse a cover on my '83 Z28 and had trouble with the antenna.I got lucky and Dave with ThirdGen had a complete antenna for sale.I have had intenetions on repairing the original antenna just haven't gotten to it yet.
Old Dec 26, 2007 | 10:43 AM
Re: power antenna
I like your idea HCR13. It's rainy today but I think tomorrow I'll hit up the 'yard and go snag a standard antenna. It'd be nice to have the antenna shaved when I get it painted anyways, lose a little weight and look a whole lot better.
Old Dec 27, 2007 | 03:30 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: power antenna
yeah, I've thought about shaving my antenna too, but now I don't have the funds for a bodyshop... As it is now, there is a small hole in the fender (original antenna hole) where the electric antenna pops out of... think of a prairie dog..) Good luck, I hope it works out
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
