General Amplifier questions
Old Jan 11, 2008 | 04:41 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
Transmission: Hydra-Matic 4L60
I have 2 12" MTX subs that can handle 400 watts RMS each, how Many watts does the amp need to be; and does it need to be mono or 2 channel?
Old Jan 11, 2008 | 08:22 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: General Amplifier questions
Ideally, you want more power (clean power) than the subs are rated for, so each sub is rated @ 400 watts, you want an amp with more than 800 watts....(2 channel, @ 4 ohms)
Depending on the power the amp is able to put out... a 500 watt mono amp (at 4 ohms) 1 speaker may be able to play 1000w at 2 ohms (2 4 ohm speakers wired in parallel) assuming each speaker is 4 ohm and 1 voice coil...
But there is no rule saying you have to do that... I had a friend with an Isuzu truck, 6 Pioneer 12's and a PPI amp that rms'd at 600 watts, so each speaker was getting about 100 watts... The box was built right, and the ports tuned right... it sounded amazing... had the cement parking garage floor oscilating in Daytona @ the spring break nationals... (the good old days
Raf
Old Jan 11, 2008 | 08:43 PM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
Get two Visonik V318XTs if your subs run on 4 ohms
Or two Kenwood KAC-8103D if your subs run on 2 ohms.
If you want to get a two channel amp, so you only need one amp, its probably gonna cost you a little more.
I'd go with those if you want cost effective power.
Old Jan 12, 2008 | 09:16 AM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
my subs do run on 4 ohms so i think im going to go with the visoniks.
and im in the process of doing a power window conversion for my car and i was wondering if i could put tweeters in the crank hole so it doesnt look empty...any suggestions?
Old Jan 12, 2008 | 02:17 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
that would probably throw off your imaging, however if you do make sure the wires dont get caught in anything inside the door
Old Jan 15, 2008 | 08:37 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
yea thanks i have the harness already so thats not a problem...does anyone know if I need to get a special harness for the head unit...i have a 2004 corvette head unit in my car so im not sure
Americanmouse
Sep 7, 2015 12:10 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
