Stock speaker wire question
Old Jan 13, 2008 | 12:31 AM
BigBadJohn's Avatar
Won nice front and rear Delco speakers on ebay for under $20 shipped
Looked at the wires for the 6x9's and they need replaced. Theyre all chopped up and exposed
I was just wondering how the rear wires were routed to the front and if it would be easy to pull new wire through the same way
Old Jan 13, 2008 | 12:40 AM
85camarojunkie's Avatar
Car: Camaro coupe
Re: Stock speaker wire question
Very simple it runs form the radio behind the pedals and then runs down the plastic door panel. Then up throught the sail panels in the rear. When i replaced mine i ran under the carpet. Didnt mess with all of the specific stuff. BUT YES VERY SIMPLE.
Old Jan 13, 2008 | 12:43 AM
BigBadJohn's Avatar
Thought it did.
I figured if it ran under the carpet I would have seen more wires under my console
Old Jan 13, 2008 | 12:53 AM
Car: Camaro coupe
nope its not as complicated, no pulling up carpet involved. Just under the door still plate and the other side same just not behind any pedals... lol... GOOD LUCK
Old Jan 13, 2008 | 01:41 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
The stock wiring is terrible. If a simple clean-up of the wire ends doesn't do the trick, you should just run new wires and just leave the old ones alone... they are bundled in conduits. Nearly impossible to get to them. I was able to squeeze a 1AWG power cable into driver's side conduit though... I was pretty impressed...
I think you need special connectors to hook up stock delco woofers... Maybe Wal-Mart sells them. For anyone else thinking of doing the same as you, I would recommend going with aftermarket. Even for $20 you could get some speakers from walmart that are at least two-ways...
Old Jan 14, 2008 | 11:23 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
But could you just tape the new wires to the old ones and just pull it thoght with out take anything out? or is it to cramped? Iv done this with like old phone wire and such.
Old Jan 14, 2008 | 11:08 PM
ScrapMaker's Avatar
Good luck with that. You won't be able to pull anything through. They are bundled too tightly. You would need to run all new wires.
The wires run through a large conduit, and are then grouped in several stages with other looms, clamps, pins, ties, etc...
Old Jan 15, 2008 | 12:20 AM
BigBadJohn's Avatar
The wire is long enough to where I can solder and heeat shrink it to make it longer but where can I find a delco style speaker connector?
Anyone have one off a junk harness?
Id maybe pay a few bucks plus shipping
Old Jan 16, 2008 | 12:23 PM
ScrapMaker's Avatar
This all seems ridiculous when a set of speakers that are at least ten times better can be had for $20 new...
I guess check a junkyard... what happened to the original delco connector? Just cut it off and solder it to the new wire...
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
