amp question
Old Feb 9, 2008 | 02:49 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
amp question
ok, im really not knolegable when it comes to car audio, and i dont want to go to the local store and get raped, so here it is. i went ahead and built my well box, and cut holes for two 10's. I have to jensen 10's but i dont know how good they are or what as i got them from a friend, so i will probably purchase other ones. What i really dont know about is amps. I have a sony Xplode Drive-5 CD player, with front and rear speakers right now which are also Sony, and i want to run two 10's, nothing that is going to make my car shake or anything like that, but something to give me some nice bass. What would be the best idea for me, im not looking to spend more than 200-300 dollars. Any help would be greatly appreciated, and im no stranger to buying used items to make stuff cheaper
Old Feb 9, 2008 | 06:22 PM
redkaz04's Avatar
Re: amp question
what's the rms power of the subwoofers...?
Old Feb 9, 2008 | 07:33 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: amp question
^^That and the Ohm rating
Old Feb 9, 2008 | 09:53 PM
92WhiteZ28's Avatar
Re: amp question
i dunno, they are set in the enclosure right now in the back of my car, i will post that when i go out there and get the numbers off of them, they are Jensens.
Old Feb 10, 2008 | 01:39 AM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Re: amp question
Being Jensen's then I almost guarentee they are 4-ohm speakers, so that's not a problem. More than likely, the speakers are around a 125 - 175rms rating. If you want something decent for not a lot of money, this is a decent amp from Best Buy
http://www.bestbuy.com/site/olspage....=1177112668775
I'm not gonna lie, I'd probably never use it(nothing against it personally), but for your subs and for you wanting to stay within a budget and get something that will get the job done, that Pioneer amp will work just fine with your Jensen subs. I've installed quite a few of these for people that want to stay cheap along with subs around the same level as yours and it really will do a decent job for ya.
Old Feb 10, 2008 | 08:37 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: amp question
I used the pioneer 7200M and one TS-W307D2. $200 total for both brand new. Built the box @ 2.5 cubic feet. Right now I'm using it at 4ohm mono. The plan was to add another sub later hence the D2, and not the D4. Pretty much if you go with a setup like this use a D4 for a single sub application, or get the D2's if you want a dual sub setup.
I suggest this only because it cost me about the same as just the amp did in that link above. The pioneer products will last much longer than jensen and give you much more bang for your buck.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
