Problem With Wiring..Help Needed!
Old Apr 16, 2008 | 03:11 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Well all my audio goodies arrived a few days ago and I have since set it all up. Now the only problem I'm having is a buzzing coming from the front speakers, but not the subs, when the car is running. If the key is in accessory, there is no buzzing whatsoever. I have the front speakers (4x6's & 6x9's) on a 300w Pyramid Amp.
Any info on what is causing this and how to correct it?
Old Apr 16, 2008 | 04:01 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
Re: Problem With Wiring..Help Needed!
You are most likely experiencing ground interference from other electronics and such when the engine is running. Some simple things to try are to get one of the ground noise interference isolators, they should be pretty cheap. You might also try regrounding the amp somewhere else although I dont know if that will really help.
Since I am not sure how you ran wires and stuff, here is some more hw. Read these articles, determine if you violated any car stereo installation rules, and then let us know.
http://www.termpro.com/articles/noise.html
http://www.crutchfield.com/S-WaDZoyp...ech/kb350.html
Last edited by Electron_Blue; Apr 16, 2008 at 04:04 PM. Reason: Automerged Doublepost
Old Apr 19, 2008 | 10:31 AM
Stippy17's Avatar
Well I rewired the ground from the battery (Where we had it) to a bolt on the firewall, and no noise!
Thanks for the help!
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
