Amp help
Old May 14, 2008 | 08:10 AM
campalger22's Avatar
Car: 1991 Firebird
Amp help
I have a really nice kenwood amp that hasn't let me down until now. It powers my 12" Pioneer sub. Anyways I put a new fuse in, it asks for a 40 amp. I got a packof them. The amp already blew two fuses in less than five minutes.
Why is my fuses blowing so quickly? Help me please...
Old May 14, 2008 | 04:14 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: Amp help
Check the ground. Don't just wiggle it around, take it loose from the car and clean (sand) the surface where it has been mounted. Usually the first place to look. You haven't changed anything recently, and this just started happening?
Old May 15, 2008 | 06:04 AM
Car: 1991 Firebird
Re: Amp help
Yep it just started happening, I'll try that tonight. Thanks
Old May 15, 2008 | 08:00 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Amp help
Something is partially shorting out.
Remove the speakers and unplug the RCA inputs to the amp.
Power up the stereo and observe the fuses. If the fuse does not blow,
you are dealing with a speaker load issue.
If the fuse blows without a load connected, or input signal the amp is
the problem.
You can also check the voltage supply to the amplifier. With the engine
off, you should read about 12 Volts DC. With the engine running, it will
jump to about 14 volts.
If the meter reads much higher than 14 volts, your alternator regulation is
screwed. The increase in voltage is causing more current to flow and blowing
the fuse.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
